Author: gregboone
Date: 2007-03-08 16:12:57 -0500 (Thu, 08 Mar 2007)
New Revision: 2656
trunk/OpenSourceBuild__README.txt
Ticket #31: Update FDO documentation
Modified: trunk/OpenSourceBuild__README.txt
--- trunk/OpenSourceBuild__README.txt 2007-03-08 21:12:06 UTC (rev 2655)
+++ trunk/OpenSourceBuild__README.txt 2007-03-08 21:12:57 UTC (rev 2656)
@@ -196,7 +196,7 @@
This script can be modifed and used to set the correct environment variables
and PATH settings.
- 10. The build_thirdparty.bat file is ude to build the FDO Thirdparty binaries. The following
+ 10. The build_thirdparty.bat file is used to build the FDO Thirdparty binaries. The following
is a general guideline on how to use the build_thirdparty.bat build script.
@@ -402,7 +402,7 @@
Thirdparty SDK components and build tools. (Refer to the Build Notes
below)
- 3. Source set environment script (bash or bourne compatible shells)
+ 3. Source the setenvironment.sh script (bash or bourne compatible shells)
source ./setenvironment.sh
@@ -737,7 +737,7 @@
initialization file, create your the file with valid values for username,
password and the service names. Run the unit test by specifying the
initialization file on the command line when executing the unit tests.
e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
NOTE: The initialization file must contain values for service, username and password.
