[fdo-commits] r2672 - trunk/Fdo/Docs
svn_fdo at osgeo.org
Fri Mar 9 14:19:42 EST 2007
Author: jacklee
Date: 2007-03-09 14:19:42 -0500 (Fri, 09 Mar 2007)
New Revision: 2672
trunk/Fdo/Docs/Makefile.am
Ticket #35
Install to /usr/local/fdo-3.2.2/docs instead of
/usr/local/fdo-3.2.2/Docs
Modified: trunk/Fdo/Docs/Makefile.am
--- trunk/Fdo/Docs/Makefile.am 2007-03-09 19:17:33 UTC (rev 2671)
+++ trunk/Fdo/Docs/Makefile.am 2007-03-09 19:19:42 UTC (rev 2672)
@@ -25,19 +25,19 @@
#install Docs
install :
- @if [ ! -d $(INSTALL_DIR)/Docs ]; then mkdir -p $(INSTALL_DIR)/Docs; fi
- @if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema; fi
- @if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/Gml ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/Gml; fi
- @if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/Xlink ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/Xlink; fi
- @if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema; fi
- @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema $(INSTALL_DIR)/Docs/XmlSchema
- @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Gml $(INSTALL_DIR)/Docs/XmlSchema/Gml
- @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Xlink $(INSTALL_DIR)/Docs/XmlSchema/Xlink
- @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/XmlSchema $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema
- @cp -u -f XmlSchema/Gml/CopyRight.txt $(INSTALL_DIR)/Docs/XmlSchema/Gml
- @cp -u -f XmlSchema/Xlink/CopyRight.txt $(INSTALL_DIR)/Docs/XmlSchema/Xlink
- @cp -u -f XmlSchema/XmlSchema/base.css $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema
+ @if [ ! -d $(INSTALL_DIR)/docs ]; then mkdir -p $(INSTALL_DIR)/docs; fi
+ @if [ ! -d $(INSTALL_DIR)/docs/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema; fi
+ @if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/Gml ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/Gml; fi
+ @if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/Xlink ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/Xlink; fi
+ @if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/XmlSchema; fi
+ @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema $(INSTALL_DIR)/docs/XmlSchema
+ @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Gml $(INSTALL_DIR)/docs/XmlSchema/Gml
+ @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Xlink $(INSTALL_DIR)/docs/XmlSchema/Xlink
+ @../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/XmlSchema $(INSTALL_DIR)/docs/XmlSchema/XmlSchema
+ @cp -u -f XmlSchema/Gml/CopyRight.txt $(INSTALL_DIR)/docs/XmlSchema/Gml
+ @cp -u -f XmlSchema/Xlink/CopyRight.txt $(INSTALL_DIR)/docs/XmlSchema/Xlink
+ @cp -u -f XmlSchema/XmlSchema/base.css $(INSTALL_DIR)/docs/XmlSchema/XmlSchema
uninstall :
- @rm -drf $(INSTALL_DIR)/Docs
+ @rm -drf $(INSTALL_DIR)/docs
More information about the fdo-commits
