[fdo-commits] r153 - branches/3.2.1/Providers/ArcSDE/Src/Provider
svn_fdo at osgeo.org
Wed Mar 14 20:50:23 EDT 2007
Author: jacklee
Date: 2007-03-14 20:50:23 -0400 (Wed, 14 Mar 2007)
New Revision: 153
branches/3.2.1/Providers/ArcSDE/Src/Provider/ArcSDEUtils.cpp
Pass NULL for the z and m parameters to the ArcSDE functions if 2d or no measure
Modified: branches/3.2.1/Providers/ArcSDE/Src/Provider/ArcSDEUtils.cpp
--- branches/3.2.1/Providers/ArcSDE/Src/Provider/ArcSDEUtils.cpp 2007-03-15 00:43:15 UTC (rev 152)
+++ branches/3.2.1/Providers/ArcSDE/Src/Provider/ArcSDEUtils.cpp 2007-03-15 00:50:23 UTC (rev 153)
@@ -712,7 +712,17 @@
arr = (type)malloc(arr##_cursize); \
+#define SETUP_BUFFERS(Z,M) \
+ if (dim & FdoDimensionality_Z) \
+ zBuffer = Z; \
+ else \
+ zBuffer = NULL; \
+ if (dim & FdoDimensionality_M) \
+ mBuffer = M; \
+ else \
+ mBuffer = NULL;
void convert_fgf_to_sde_shape(ArcSDEConnection *connection, FdoByteArray* fgf, SE_COORDREF coordref, SE_SHAPE& result_shape, bool bCropToExtents)
LONG lResult = SE_SUCCESS;
@@ -730,6 +740,9 @@
SE_ENVELOPE given_coordref_envelope;
SE_SHAPE *work_shape = NULL;
FdoException *exception = NULL;
+ LFLOAT *zBuffer = NULL;
+ LFLOAT *mBuffer = NULL;
try
@@ -781,6 +794,8 @@
work_shape = &result_shape;
+ SETUP_BUFFERS(connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM);
// Convert FdoIGeometry to SE_SHAPE:
switch (geom->GetDerivedType())
@@ -835,7 +850,7 @@
// Populate the SE_SHAPE based on the XY,Z, and M arrays:
- lResult = SE_shape_generate_point (totalNumPoints, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM, *work_shape);
+ lResult = SE_shape_generate_point (totalNumPoints, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer, *work_shape);
handle_sde_err<FdoCommandException>(connection->GetConnection(), lResult, __FILE__, __LINE__, ARCSDE_CONVERT_SHAPE_FAILED, "Failed to convert FGF geometry to ArcSDE shape.");
break;
@@ -868,7 +883,7 @@
- lResult = SE_shape_generate_line (totalNumPoints, 1, NULL, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM, *work_shape);
+ lResult = SE_shape_generate_line (totalNumPoints, 1, NULL, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer, *work_shape);
break;
@@ -921,7 +936,7 @@
- lResult = SE_shape_generate_line (totalNumPoints, numLineStrings, connection->mGeomBuffer_offsets, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM, *work_shape);
+ lResult = SE_shape_generate_line (totalNumPoints, numLineStrings, connection->mGeomBuffer_offsets, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer, *work_shape);
break;
@@ -985,7 +1000,7 @@
- lResult = SE_shape_generate_polygon (totalNumPoints, 1, NULL, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM, *work_shape);
+ lResult = SE_shape_generate_polygon (totalNumPoints, 1, NULL, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer, *work_shape);
break;
@@ -1066,7 +1081,7 @@
- lResult = SE_shape_generate_polygon (totalNumPoints, numPolygons, connection->mGeomBuffer_offsets, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM, *work_shape);
+ lResult = SE_shape_generate_polygon (totalNumPoints, numPolygons, connection->mGeomBuffer_offsets, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer, *work_shape);
break;
@@ -1948,6 +1963,8 @@
SE_SHAPE *resultShapes = NULL;
SE_COORDREF coordref = NULL;
try
@@ -1983,7 +2000,8 @@
RESIZE(connection->mGeomBuffer_pointsM, double*, numPoints * sizeof(double));
- lResult = SE_shape_get_all_points (shape, SE_DEFAULT_ROTATION, connection->mGeomBuffer_part_offsets, connection->mGeomBuffer_subpart_offsets, connection->mGeomBuffer_pointsXY, connection->mGeomBuffer_pointsZ, connection->mGeomBuffer_pointsM);
+ lResult = SE_shape_get_all_points (shape, SE_DEFAULT_ROTATION, connection->mGeomBuffer_part_offsets, connection->mGeomBuffer_subpart_offsets, connection->mGeomBuffer_pointsXY, zBuffer, mBuffer);
handle_sde_err<FdoException>(lResult, __FILE__, __LINE__, ARCSDE_FAILED_PROCESSING_SPATIAL_CONDITION, "Failed to process the given spatial condition.");
// Get shape's coordref:
More information about the fdo-commits
