[fdo-commits] r2717 - trunk/Utilities/SQLiteInterface
svn_fdo at osgeo.org
Mon Mar 26 16:48:26 EDT 2007
Author: badreddinekaroui
Date: 2007-03-26 16:48:26 -0400 (Mon, 26 Mar 2007)
New Revision: 2717
trunk/Utilities/SQLiteInterface/SQLiteBTree.cpp
trunk/Utilities/SQLiteInterface/SQLiteBTree.h
trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp
trunk/Utilities/SQLiteInterface/SQLiteInterface.vcproj
See trac#53: upgrade the Sqlite library to the latest version 3.3.13 and add more unit tests
Modified: trunk/Utilities/SQLiteInterface/SQLiteBTree.cpp
--- trunk/Utilities/SQLiteInterface/SQLiteBTree.cpp 2007-03-26 20:46:30 UTC (rev 2716)
+++ trunk/Utilities/SQLiteInterface/SQLiteBTree.cpp 2007-03-26 20:48:26 UTC (rev 2717)
@@ -31,11 +31,17 @@
m_bOwner = true;
+#ifdef SQLITE_3_1
SQLiteBTree::SQLiteBTree( Btree *bt ) : m_pBt( bt )
m_bOwner = false;
+#else
+SQLiteBTree::SQLiteBTree( Btree *bt, sqlite3 *db ) : m_pBt( bt ), m_pDB( db )
+ m_bOwner = false;
+#endif
SQLiteBTree::~SQLiteBTree(void)
@@ -49,8 +55,11 @@
int SQLiteBTree::open( const char* fileName, int nCache, int flags )
int rc;
+#ifdef SQLITE_3_1
rc = sqlite3BtreeOpen(fileName, &m_pBt, flags);
+#else
+ rc = sqlite3BtreeOpen(fileName, m_pDB, &m_pBt, flags);
+#endif
if( rc!=SQLITE_OK ){
return rc;
Modified: trunk/Utilities/SQLiteInterface/SQLiteBTree.h
--- trunk/Utilities/SQLiteInterface/SQLiteBTree.h 2007-03-26 20:46:30 UTC (rev 2716)
+++ trunk/Utilities/SQLiteInterface/SQLiteBTree.h 2007-03-26 20:48:26 UTC (rev 2717)
@@ -32,14 +32,19 @@
private:
Btree *m_pBt;
+#ifndef SQLITE_3_1
+ sqlite3 *m_pDB;
+#endif
bool m_bOwner;
public:
SQLiteBTree(void);
- SQLiteBTree( Btree *bt );
+#ifdef SQLITE_3_1
+ SQLiteBTree( Btree *bt );
+#else
+ SQLiteBTree( Btree *bt, sqlite3 *db );
+#endif
~SQLiteBTree(void);
Modified: trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp
--- trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp 2007-03-26 20:46:30 UTC (rev 2716)
+++ trunk/Utilities/SQLiteInterface/SQLiteDataBase.cpp 2007-03-26 20:48:26 UTC (rev 2717)
@@ -43,7 +43,11 @@
SQLiteBTree* SQLiteDataBase::BTree()
if( m_pBtree == NULL )
+#ifdef SQLITE_3_1
m_pBtree = new SQLiteBTree( mpDB->aDb[0].pBt );
+#else
+ m_pBtree = new SQLiteBTree( mpDB->aDb[0].pBt, mpDB );
+#endif
return m_pBtree;
@@ -60,9 +64,13 @@
if( sqlite3_open(fullPath, &mpDB) == SQLITE_OK )
- ExecuteNonQuery("create table fdo_master(name text, rootpage integer);"); // May fail is the table was already created
+ ExecuteNonQuery("create table fdo_master(name text, rootpage integer);"); // expected to fail if the table was already created
sqlite3BtreeSetPageSize( mpDB->aDb[0].pBt, SQLiteDB_PAGESIZE, -1 );
- sqlite3BtreeSetSafetyLevel( mpDB->aDb[0].pBt, 1);
+#ifdef SQLITE_3_1
+ sqlite3BtreeSetSafetyLevel( mpDB->aDb[0].pBt, 1);
+#else
+ sqlite3BtreeSetSafetyLevel( mpDB->aDb[0].pBt, 1, 1);
+#endif
sqlite3BtreeSetAutoVacuum( mpDB->aDb[0].pBt, 0 );
sqlite3_busy_timeout(mpDB, 1000*60); // 60 seconds
Modified: trunk/Utilities/SQLiteInterface/SQLiteInterface.vcproj
--- trunk/Utilities/SQLiteInterface/SQLiteInterface.vcproj 2007-03-26 20:46:30 UTC (rev 2716)
+++ trunk/Utilities/SQLiteInterface/SQLiteInterface.vcproj 2007-03-26 20:48:26 UTC (rev 2717)
@@ -41,7 +41,7 @@
<Tool
Name="VCCLCompilerTool"
Optimization="0"
- AdditionalIncludeDirectories="$(FDOTHIRDPARTY)\Sqlite3.1.5\Src"
+ AdditionalIncludeDirectories="$(FDOTHIRDPARTY)\Sqlite3.3.13\Src"
PreprocessorDefinitions="WIN32;_DEBUG;_LIB;_CRT_SECURE_NO_DEPRECATE"
MinimalRebuild="true"
BasicRuntimeChecks="3"
@@ -110,7 +110,7 @@
EnableIntrinsicFunctions="true"
FavorSizeOrSpeed="1"
OmitFramePointers="true"
PreprocessorDefinitions="WIN32;NDEBUG;_LIB;_CRT_SECURE_NO_DEPRECATE"
StringPooling="true"
RuntimeLibrary="2"
More information about the fdo-commits
