[fdo-dev] [Proposal] FGF<->WKB converters as common utils
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Tue Aug 8 15:11:22 EDT 2006
I like Mateusz's suggestion. But I would suggest movnig this stuff to
someplace more global such as ProvidersCommon, where multiple providers
(GenericRDBMS-based or not) can share the same code instead of each
having their own copy. Traian, wouldn't you prefer re-using (and
possibly enhancing) existing code rather than reinventing the wheel? :-)
Pierre
-----Original Message-----
Sent: August 8, 2006 3:07 PM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] [Proposal] FGF<->WKB converters as common utils
I also have functions to do that conversion in the OGR provider source
code. At least, I have WkbToFgf, and will soon be adding the reverse,
when I add write support to the OGR provider. Search for
OgrConnection::Wkb2Fgf in the attached file.
Traian
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, August 08, 2006 3:03 PM
Subject: [fdo-dev] [Proposal] FGF<->WKB converters as common utils
I'd like to present small proposal about constituting FGF<->WKB
converters as common utilities.
Currently, I know about two procedures that can be used to convert
geometries between FGF and OGC WKB formats:
GeometryFromWkb() and WkbFromGeometry()
Both functions are coupled with MySQL driver for RDBI layer:
fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.h
fdordbms/trunk/Providers/GenericRdbms/Src/MySQL/Driver/Geometry.c
I see these functions may be used in PostGIS driver too, because PostGIS
also operates on OGC WKB format.
So, my proposal is to move Geometry.h and Geometry.c to a common
location, for example to:
fdordbms/trunk/Providers/GenericRdbms/Inc/Util/Geometry.h
fdordbms/trunk/Providers/GenericRdbms/Src/Util/Geometry.c
What do you think?
p.s. Should I report such proposals to Project Tracker as 'enhancements'
or posting it here is fine?
Best regards
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org For additional
commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals
