[fdo-dev] [Proposal] FGF<->WKB converters as common utils
Mateusz Loskot
mateusz at loskot.net
Tue Aug 8 15:56:07 EDT 2006
Pierre Dalcourt wrote:
> Yes, that is the location I was thinking of.
> However, now that I think a bit more, I believe you can already convert
> AGF<->WKB using the existing AgfGeometryFactory class. See
> Fdo\Inc\Geometry\Fgf\Factory.h , specifically the methods
> CreateGeometryFromWkb() and GetWkb().
I believe you mean fdocore/Fdo/Unmanaged/Inc/Geometry/Fgf/Factory.h
Yes, I found it. If this is factory functions does the same as
GeometryFromWkb() and WkbFromGeometry() functions then I think there is
no need for new common converters.
Best regards
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals
