[fdo-dev] FdoInt32 or int
Greg Boone greg.boone at autodesk.com
Mon Aug 14 10:15:05 EDT 2006
I recommend using FdoInt32.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Sunday, August 13, 2006 7:07 PM
To: dev at fdo.osgeo.org
Subject: [fdo-dev] FdoInt32 or int
I noticed that both types are mixed in some places.
For example, two function members prototypes:
- from base class
FdoInt32* FdoRdbmsCommandCapabilities::GetCommands(FdoInt32& size),
- and prototype of the same function but overriden in subclass
derived from the base above:
int* FdoRdbmsPostGisCommandCapabilities::GetCommands(int& size);
The base uses FdoInt32 and the subclass uses C++ int, so are these
types considered as interchangeable in FDO?
Size of int is depends on C++ implementation and system architecture,
but FdoInt32 says "my size is 32 bit everywhere".
So, which type is recommended to use as 32-bit integer in FDO:
FdoInt32 or int?
Thanks in advance
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
