[fdo-dev] [UnitTest] More detailed log
Mateusz Loskot mateusz at loskot.net
Mon Aug 28 10:49:41 EDT 2006
Pierre Dalcourt wrote:
> FYI: I will be dropping some changes this week to the cppunit code in
> the SVN at fdocore.osgeo.org.
Pierre,
OK, thanks.
> These changes which cause cppunit (when
> running in text mode, as opposed to GUI mode) to output the name of each
> unit test before it is run and the date/time it started running.
BTW, is it possible to use the GUI mode on Unix?
> This will help isolate crashes which prevent you from getting cppunit's
> informative summary at the end.
That's great, thanks!
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
