[fdo-dev] [UnitTest] More detailed log
Pierre Dalcourt pierre.dalcourt at autodesk.com
Mon Aug 28 13:51:59 EDT 2006
There seems to be a Qt UI implementation for linux.
I guess if you pass "-gui" (or some similar switch) as a command-line
argument to your cppunit test linux executable it will use the Qt
implementation.
Pierre
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: August 28, 2006 10:50 AM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] [UnitTest] More detailed log
Pierre Dalcourt wrote:
> FYI: I will be dropping some changes this week to the cppunit code in
> the SVN at fdocore.osgeo.org.
Pierre,
OK, thanks.
> These changes which cause cppunit (when
> running in text mode, as opposed to GUI mode) to output the name of
each
> unit test before it is run and the date/time it started running.
BTW, is it possible to use the GUI mode on Unix?
> This will help isolate crashes which prevent you from getting
cppunit's
> informative summary at the end.
That's great, thanks!
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
