[fdo-dev] AM_CXXFLAGS instead of CXXFLAGS
Mateusz Loskot mateusz at loskot.net
Mon Aug 28 19:04:42 EDT 2006
Greg Boone wrote:
> This is a reasonable suggestion. Is the Makefile.am files the only
> locations that would have to change?
AFAIK, yes, only to Makefile.am.
It applies to CXXFLAGS substitution, for subdirectories, using
@CXXFLAGS@ placeholder, which usually is used in Makefile.am.
Usually, configure.in defines default flags used globally.
Every additional flags used locally in subdirectories
are set with AM_CXXFLAGS.
Similarly, there are also AM_CPPFLAGS and AM_LDFLAGS.
For example,
1. configure.in includes default flags definition:
CXXFLAGS="${CXXFLAGS} -Wall -ansi -pedantic -Wno-long-long"
----------^^^^^^^^^^ - important
This enables users to define custom flags as follows:
$ CXXFLAGS="-g -Wnonnull" ./configure
what will generate:
CXXFLAGS="-g -Wnonnull -Wall -ansi -pedantic -Wno-long-long"
2. If some subdirectory needs specific local flags,
then <path-to-subdir>/Makefile.am file comletes default flags definition
with local flags as follows:
AM_CXXFLAGS = -fPIC -Wuninitialized
what finally gives:
CXXFLAGS="-fPIC -Wuninitialized -Wnonnull -Wall -ansi -pedantic
-Wno-long-long"
The same way AM_CPPFLAGS and AM_LDFLAGS may be used.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
