[fdo-dev] XMLSchema.xsd not UTF-8?
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Mon Nov 6 13:14:35 EST 2006
Mateusz,
Yes, it should be UTF-8 as far as I know :-)
If you can log a defect in ProjectTracker and drop the file with the
updates you already made that would be very helpful.
Thanks,
Pierre
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: November 6, 2006 12:52 PM
To: dev at fdo.osgeo.org
Subject: Re: [fdo-dev] XMLSchema.xsd not UTF-8?
Pierre Dalcourt wrote:
> The problem lies simply in that every person that makes an edit to
such
> a file risks introducing non-utf8 characters if they are using a
non-utf
> editor. In the case of XMLSchema.xsd it was a copyright notice that
was
> added at some point which inadvertently caused this problem.
Yes, I understand it.
But what's the final conclusion?
Should this file be UTF-8 or not?
I can fix this issue myself, but it's probably other users will
come reporting this bug again, so I'd suggest to fix it:
https://fdo.osgeo.org/servlets/Scarab?id=FDO264
Cheeers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals
