Property Sheet for VC++ projects
Mateusz Loskot
mateusz at loskot.net
Tue Nov 28 12:08:20 EST 2006
What do you think about adding VC++ Property Sheet (.vsprops) with
common environment variables/macros definition to FDO project files?
AFAIK, currently, all environment variables on Windows can be set:
1. from .bat scripts what is unusable for building from VC++ IDE
2. or manually as system/account-wide env variables
With Property Sheet, FDOTHIRDPARTY, FDOUTILITIES and other env variables
could be set from IDE and stored in Property Sheet.
Next, projects can inherit these settings from common Property Sheet.
What is your opinion?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals
