FDO Unit Test fails
Mateusz Loskot
mateusz at loskot.net
Wed Oct 4 03:51:44 EDT 2006
Yesterday, I updated fdocore after a few days.
I cleaned up my working copy and removed everything from the
installation directory usr/local/fdo-3.2.0.
Next, I run svn update and built:
. ./setenvironment.sh
./build_thirdparty.sh
./build_linux.sh
Next, I did run UnitTest program and here is what I got:
mloskot:~/dev/fdo/_svn/Fdo/UnitTest$ ./UnitTest
In-memory limited conversion to unaligned FGF Polygons, retained as FGF...
0.075332 sec for 14915 positions in 343 polygons (4553 geom/s)
In-memory use of limited retained, unaligned FGF, accessed via streamed
geometries...
0.234421 sec for 304095 positions in 7000 streamed geometries (29860 geom/s)
............................Filter = ( Width*Length ) AS Area, Area = 123
.............................ERROR (XSL Processor): 'xsl:variable' has
an invalid 'junk' attributeWARNING (XSL Processor): At source node
'#document/DataSet', '' is an illegal element name. The element will not
be addedFDO_28_UTF8FAILURE
F.........................................
UnitTestUtil.cpp:47:Assertion
Test name: 7XmlTest.testXsl
FDO_28_UTF8FAILURE
Failures !!!
Run: 100 Failure total: 1 Failures: 1 Errors: 0
Does anyone has idea where is the problem?
Is this something wrong with my environment?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals
