[fdo-dev] Query on MySQL FDO
Romica Dascalescu Romica.Dascalescu at autodesk.com
Tue Oct 10 14:13:33 EDT 2006
Because '[FDO Open Source]\Utilities' directory is not on your local
disk I think you took from SVN only fdo, thirdparty and rdbms. You need
also the utilities for providers.
You can use checkoutsvn.bat to get/update your working folder by using
-w command e.g.:
checkoutsvn.bat -w=fdocore -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
Or
checkoutsvn.bat -w=fdo -w=utilities -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
The option fdocore include utilities option.
Before running checkoutsvn.bat, please update it from SVN.
After this command you should have and build the utilities without any
problems.
If you still have problems please let me know.
Regards,
Romica.
-----Original Message-----
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Saturday, September 30, 2006 2:55 AM
To: dev at fdo.osgeo.org; users at fdo.osgeo.org
Subject: [fdo-dev] Query on MySQL FDO
We are working on MySQL FDO open source and are facing a few problems on
the
way. Please advise how do we go about it and where can we get the
information regarding the missing links.
When we open the MySQL provider project 'MySql.vcproj' in
Visual Studio .NET then it also opens the dependency projects. Out of
these dependency projects some of the projects are opened from the
'[FDO Open Source]\Utilities' directory which is not there.
The dependency projects are
	a)	[FDO Open Source]\Utilities\Common\FdoCommon.vcproj
	b)	[FDO Open Source]\Utilities\SchemaMgr\SchemaMgr.vcproj
	c)	[FDO Open
Source]\Utilities\SchemaMgr\LogicalPhisycal.vcproj
	d)	[FDO Open Source]\Utilities\SchemaMgr\SMMessage.vcproj
	e)	[FDO Open Source]\Utilities\SchemaMgr\Overrides.vcproj
	f)	[FDO Open Source]\Utilities\SchemaMgr\Physical.vcproj
The Utilities folder for MySQL FDO is missing on the site.
Best Regards
Rajneesh Verma
KLG Systel Limited,
Gurgaon, India
+91-124-4129900 ext. 36
+91-9811724149
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
