[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Rajneesh Verma rajneesh at klgsystel.com
Wed Oct 18 00:10:14 EDT 2006
Hi Romica,
May we know the version which is supported by MYSQL provider?
Regards
Rajneesh
  _____
From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
Sent: Tuesday, October 17, 2006 8:38 PM
To: dev at fdo.osgeo.org; Rajneesh Verma; Manjeet Sharma
Cc: ganesh.bansal at daffodildb.com; parveen.agarwal at daffodildb.com
Subject: RE: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Rajneesh,
For that version of Map which you have, is no open source code for MySQL
provider available.
For that version of Map you have only FDO, SHP and SDF providers available.
Regards,
Romica.
-----Original Message-----
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Tue 10/17/2006 9:34 AM
To: Romica Dascalescu; 'Manjeet Sharma'; dev at fdo.osgeo.org
What versions does it support?
Regards
Rajneesh
  _____
Sent: Tuesday, October 17, 2006 6:21 PM
To: Manjeet Sharma; dev at fdo.osgeo.org
Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com;
Hi Manjeet,
Latest FDO is not supported by the version of Map which you having.
Regards,
Romica.
From: Manjeet Sharma [mailto:manjeet.sharma at daffodildb.com]
Sent: Tue 10/17/2006 1:07 AM
Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Romica,
I am sending you the following configuration details for FDO provider :
Product name: Autodesk Map 3D 2007
Product version: A.54.0 (UNICODE)
Product service pack: 0
License type: Standalone - Locked
License behavior: Unregistered Version
License usage type: In Trial
FDO provider version: 3.2.0.0
and we could not find the library file MgFdoMySQLOverrides.dll  after
build process at the following locations:
 \\Providers\GenericRdbms\Managed\bin\debug\ and
\\Providers\GenericRdbms\Managed\bin\release\
but we have another library file
OSGeo.FDO.Providers.MySQL.Overrides.dll at the same path. we tried to
use the same but the error message during autodesk startup is same as
i have told you earlier.
i have also tried all the newly build fdo core dll file (including
debug dependencies (Xalan-C_1_7_0D.dll, XalanMessages_1_7_0D.dll,
xerces-c_2_5_0D.dll) by placing all those files.
Right now i am trying to build the FDO provider  using FDO 3.0.0.0 version
Thanks
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061018/a887b4c2/attachment.html
More information about the Fdo-internals mailing list
