FW: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Rajneesh Verma rajneesh at klgsystel.com
Fri Oct 20 03:27:09 EDT 2006
Hi Romica,
I need some information from you  that regarding these issues:
Is it possible to Build the open source code for FDO provider for MySQL with
open source FDO 3.1  means , is  open source  MySQL FDO provider (that i
have) is compaitible with open source FD0 3.1. I need this information , as
I am getting errors, when I try to build Fdo provider for MySQL with FDO
3.1.
If  above mentioned build process is possible, then can i Integrate the
generated .dll files with Autodesk Map 2007 successfully.
Thanks
On 10/18/06, Robert Fortin <robert.fortin at autodesk.com> wrote:
Map 2007 is compatible with FDO 3.1 providers.  You can find tarballs on
https://fdo.osgeo.org/servlets/ProjectDocumentList?folderID=93
<https://fdo.osgeo.org/servlets/ProjectDocumentList?folderID=93&expandFolder
=93&folderID=0> &expandFolder=93&folderID=0  for SDF and SHP.  For preview
of additional providers (ArcSDE, MySQL, ODBC, WFS/WMS), you can find them at
https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100
<https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100&expand
Folder=100&folderID=0> &expandFolder=100&folderID=0
R050 is basically equivalent to Map 2007 SP2 and MapGuide 1.0 release.
R071 is part of the next service pack for MapGuide.  It is compatible with
Map 2007 SP3.
MapGuide 1.2  will be supporting FDO 3.2 providers.  Map will support this
version of FDO in its next release.
RF
  _____
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Wednesday, October 18, 2006 12:10 AM
To: Romica Dascalescu; dev at fdo.osgeo.org; Partha P. Sarkar
Cc: 'Manjeet Sharma'
Subject: RE: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Romica,
May we know the version which is supported by MYSQL provider?
Regards
Rajneesh
  _____
From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
Sent: Tuesday, October 17, 2006 8:38 PM
To: dev at fdo.osgeo.org; Rajneesh Verma; Manjeet Sharma
Cc: ganesh.bansal at daffodildb.com ; parveen.agarwal at daffodildb.com
Hi Rajneesh,
For that version of Map which you have, is no open source code for MySQL
provider available.
For that version of Map you have only FDO, SHP and SDF providers available.
Regards,
Romica.
-----Original Message-----
Sent: Tue 10/17/2006 9:34 AM
To: Romica Dascalescu; 'Manjeet Sharma'; dev at fdo.osgeo.org
Cc: ganesh.bansal at daffodildb.com; parveen.agarwal at daffodildb.com
What versions does it support?
Regards
Rajneesh
  _____
Sent: Tuesday, October 17, 2006 6:21 PM
To: Manjeet Sharma; dev at fdo.osgeo.org
Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com;
Hi Manjeet,
Latest FDO is not supported by the version of Map which you having.
Regards,
Romica.
From: Manjeet Sharma [mailto:manjeet.sharma at daffodildb.com]
Sent: Tue 10/17/2006 1:07 AM
Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Romica,
I am sending you the following configuration details for FDO provider :
Product name: Autodesk Map 3D 2007
Product version: A.54.0 (UNICODE)
Product service pack: 0
License type: Standalone - Locked
License behavior: Unregistered Version
License usage type: In Trial
FDO provider version: 3.2.0.0
and we could not find the library file MgFdoMySQLOverrides.dll  after
build process at the following locations:
 \\Providers\GenericRdbms\Managed\bin\debug\ and
\\Providers\GenericRdbms\Managed\bin\release\
but we have another library file
OSGeo.FDO.Providers.MySQL.Overrides.dll at the same path. we tried to
use the same but the error message during autodesk startup is same as
i have told you earlier.
i have also tried all the newly build fdo core dll file (including
debug dependencies (Xalan-C_1_7_0D.dll, XalanMessages_1_7_0D.dll,
xerces-c_2_5_0D.dll) by placing all those files.
Right now i am trying to build the FDO provider  using FDO 3.0.0.0 version
Thanks
Manjeet Sharma
Software Engineer
Daffodil Software Ltd.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061020/0bc5934e/attachment.html
More information about the Fdo-internals mailing list
