[fdo-dev] sdf provider
Haris Kurtagic haris at sl-king.com
Tue Oct 31 18:16:38 EST 2006
Thanks, now I got it.
Haris
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wednesday, November 01, 2006 12:13 AM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] sdf provider
In the past, the SDF provider did not require a non-null value for the
spatial context association of the geometry property. This is because
there is one spatial context, so it is clear which one to use and there
was no need to link the geometry property to the spatial context.
Therefore there are existing files with null association.
Traian
Sent: Tuesday, October 31, 2006 5:51 PM
See inline...
Sent: Tuesday, October 31, 2006 4:36 PM
Subject: [fdo-dev] sdf provider
1. When I execute command apply schema on sdf which already has schema
applied in it, sdf provider returns error that schema already exists.
What is a way to add new class into existing sdf ?
[GB] No. You can only ApplySchema once for an SDF file
2. In some SDF's sdf provider is returning null for
GetSpatialContextAssociation
<https://fdo.osgeo.org/nonav/docs/FDO_API/df/d40/class_fdo_geometric_pro
perty_definition_ec20045b117ee761d323102dac225e68.html#ec20045b117ee761d
323102dac225e68>
    Is this in line whith fdo interface ?
[GB] I believe when you create the SDF file, you have to specify the
Spatial Context as part of the creation parameters.
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061101/0feeea8c/attachment.html
More information about the Fdo-internals mailing list
