[fdo-dev] Standard exceptions handling practice
Mateusz Loskot
mateusz at loskot.net
Fri Sep 1 15:29:25 EDT 2006
Greg Boone wrote:
> I would write something like...
> try
> // operation that throws exception derived
> // from standard ex. type std::exception
> bar();
> catch ( FdoException* ex )
> throw FdoException::Create(
> NlsMsgGet(XYZ_123_FAIL_BAR, "bar() failed"), ex);
> catch ( std::exception &e )
> FdoExceptionP cause =
> FdoException::Create((FdoString*)(FdoStringP(e.what())));
> NlsMsgGet(XYZ_123_FAIL_BAR, "bar() failed"), cause);
Yes, it's good especially for wrapping whole function body.
But if one want to wrap single operation that may throw known
exception, then std::exception catch should be enough,
for example (note, it's just a general one, for illustration purpose):
void foo()
s="123456";
try
int i = boost::lexical_cast<int>(s);
catch(boost::bad_lexical_cast& e)
throw FdoException::Create(...);
// .. rest of long function body
What do you think about adding overloaded
version of FdoException::Create() to accept std::exception?
This would be provide more elegant catch of standard exceptions
For example:
FdoException* FdoException::Create(FdoString* message,
std::exceptipn const& stdex)
// Compile/Concatenate/Generate/whatever a message here
// message + stdex.what()
return new FdoException(message);
Then client's catch could look as follows
NlsMsgGet(XYZ_123_FAIL_BAR, "foo and bar failed"),
e);
Or something similar, for example to compile FdoException from
another FdoException-derived type + std::exception.
Also, message concatenation is not important, but would useful.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals
