test data fdo 3.1.0
a.penitente
a.penitente at gepaspa.com
Wed Sep 20 12:17:21 EDT 2006
I read il file OpenSourceTestData_README.txt from fdo-3.1.0_data_R050.tar.gz
and the instructions are for fdo-3.0.0, but I must install fdo-3.1.0 for
mapguide opensouce
if I replace 3.0 with 3.1 the tests they do not work.
I ask help you
I. Linux Notes:
1. Extract the FDO Unit Test data to the same location as the FDO OpenSource
Files (see OpenSourceBuild__README.txt)
2. To run the FDO unit tests, you must set LD_LIBRARY_PATH as follows:
$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:
/usr/local/gis/fdo/3.0:/usr/local/gis/fdo/3.0/Shp:/usr/local/gis/fdo/3.0/SDF
<Fdo OpenSource Location>/thirdparty/linux/cppunit/lib
(Note: The above path should be entered all on one line.)
3. Due to a path issue encountered in the FDO OpenSource Unit test(s), you
must
move some files in a directory.
After the FDO UnitTest data files are extracted, move the directory:
<OpenSource_FDO>/providers/SDFPlus/UnitTest/data/
to
<OpenSource_FDO/providers/data/
4. In order to run the various FDO Provider UnitTests on Linux follow
the following steps:
'FDO SDF Provider'
cd <OpenSource_FDO>/providers/SDFPlus/UnitTest
run ./UnitTest
'FDO SDF Provider'
cd <OpenSource_FDO>/providers/Shp/src/UnitTest
run ./UnitTest
II. Linux Steps for Extracting UnitTest Data:
1. gunzip fdo-3.0.0_data.tar.gz
2. tar -xvf fdo-3.0.0_data.tar.gz
<end>
thank you
albina penitente
More information about the Fdo-internals
