[fdo-internals] FDO env. variables
Haris Kurtagic haris at sl-king.com
Wed Apr 11 10:43:13 EDT 2007
The additional work I have is when compiling FDO and MapGuide itself.
If I work with different versions ( and I do ) I need to change env, variables to compile it.
I would like to be able to easier compile any version of FDO and MG without changes in env. variable.
Regarding provider i have multiple configuration’s beacuse I am building and supporting all active version’s of FDO’s.
When I am adding new functionality I am adding it in all flavours of provider.
Haris
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: 10. april 2007 14:56
To: FDO Internals Mail List; FDO Internals Mail List
Subject: RE: [fdo-internals] FDO env. variables
Hi Harris,
We do not have any plans to move off of the env variable usage any time soon. Eventually it will happen but it would require a fair bit of work.
If I remember correctly, you use a single .Net solution, with multiple configurations, to enable compilation of multiple releases of your project. Since the source for 3.2.1, 3.2.2, 3.3.0 are now in 3 different FDO svn repositories,  I am not sure why you need to maintain such a mechanism. It seems to only complicate your build process.
Greg
	-----Original Message-----
	From: fdo-internals-bounces at lists.osgeo.org on behalf of Haris Kurtagic
	Sent: Mon 4/9/2007 6:35 AM
	Cc:
	Subject: [fdo-internals] FDO env. variables
	Right now I am working with three version’s of FDO (3.1, 3.2, 3.2.2 ).
	Problem I am having is setting environment variables to be  able to compile those
	Right now I need to change variables FDO FDOTHIRDPARTY,.. to compile fdo ( perhaps another usable way , exists ? ).
	In provider’s I have  changed to use relative paths instead of variables.
	Is this something which we can change for FDO too?
	How are others working with multiple fdo version’s ?
	Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070411/9bbd3b67/attachment.html
More information about the fdo-internals mailing list
