[fdo-internals] Logging on exceptions
Mateusz Loskot
mateusz at loskot.net
Wed Apr 25 12:15:02 EDT 2007
Traian Stanev wrote:
> Not sure if the example is out of context, but why do you catch an
> FdoException only to rethrow it as another? That only hides the real
> source of the error. Is it just for the logging?
Traian,
I think the example is not very good.
I do catch and rethrow if:
- I want to translate std/boost exceptions to FDO
- I need to clean resources manually
try
catch
PQclean(result);
} // rethrow
- and sometimes, when I have to clean resources, I want to put
additional information, so I rethrow manually with some translation
try
catch
PQclean(result);
throw ....
I have to confess that I've never used exceptions rolling practice
as it occurs in FDO, so I may be lack of knowledge how and when it
should be used and when it's not recommended.
Doesn't the rolling mechanism preserve actual
context of source of error well?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
