[fdo-internals] New RFC posted
Jason Birch
Jason.Birch at nanaimo.ca
Wed Aug 22 13:28:35 EDT 2007
Yes, thanks.
I don't know if it matters if this is added to the RFC, but it should
probably be in the docs somewhere...
Jason
Subject: RE: [fdo-internals] New RFC posted
Hi Jason
For functions like MOD and REMAINDER, the intent is to use the same data
type for the return value as used for the first parameter. In some
cases, this is not possible and hence the return type is different. For
example, look at the signatures for the function MOD where the first
parameter is an int16 and the second parameter either a decimal, double,
int16, int32, int64 or single data type. In this example, the return
value differs based on the provided values:
Signature
Return Value Data Type
Mod (FdoDataType_Int16, FdoDataType_Decimal)
FdoDataType_Double
Mod (FdoDataType_Int16, FdoDataType_Double)
FdoDataType_Double
Mod (FdoDataType_Int16, FdoDataType_Int16)
FdoDataType_Int16
Mod (FdoDataType_Int16, FdoDataType_Int32)
FdoDataType_Int16
Mod (FdoDataType_Int16, FdoDataType_Int64)
FdoDataType_Int16
Mod (FdoDataType_Int16, FdoDataType_Single)
FdoDataType_Single
Does that answer your question?
Thanks
Thomas
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070822/64b813ee/attachment.html
More information about the fdo-internals
