[fdo-internals] RE: Defects in PostGIS provider
Orest Halustchak orest.halustchak at autodesk.com
Fri Aug 24 08:27:17 EDT 2007
Yes, our position was that removing a class definition from a data store
should be prevented if there is still data of that class in the data
store. You have to delete the data first, then you can remove the class
definition.
Thanks,
Orest.
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Friday, August 24, 2007 8:20 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] RE: Defects in PostGIS provider
Haris Kurtagic wrote:
> Hm, If I am looking in database behavior it would be normal to delete
>  class/table if data is in the class/table.
> So in my opinion it is expected behavior to be able to delete class
> regardless of data in it.
Haris,
I'm not sure if that would be safe.
Considering that a feature class is not always mapped to single table,
but may be mapped to N physical tables, deleting data along with table
is potentially unsafe for data integrity.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
