[fdo-internals] Disable GEOS support explicitly
Mateusz Loskot
mateusz at loskot.net
Wed Dec 12 02:18:47 EST 2007
Kenneth, GEOGRAF A/S wrote:
> If you remove GEOS from the OGR Provider, it will perform all
> intersection checks as BBOX overlap only.
> This will cause bad behavior with both selection and tooltip.
Yes, I perfectly understand it.
I'm not suggesting to disable GEOS completely.
> This can be fixed by using the FDO geometry operations instead of the
> OGR which rely on GEOS.
Unfortunately, OGR Provider relies on OGR and OGR replies on GEOS.
This chain is not replaceable with anything else.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
