[fdo-internals] Fixed: Loading WFS layer does not get the geometry
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Tue Feb 13 12:29:53 EST 2007
Author: romicadascalescu
Date: 2007-02-13 13:17:50 -0500 (Tue, 13 Feb 2007) New Revision: 2509
trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp
trunk/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h
trunk/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.cpp
trunk/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.h
trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp
trunk/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h
If case the geometry is not encapsulated in a object we deserialize the
geometry and match the names (only in case number of geometries on class
definition is one)
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070213/a80087aa/attachment.html
More information about the fdo-internals
