[fdo-internals] Code Submission Notification: FDO4: Update API
documentation included in the FDO header files
Greg Boone
greg.boone at autodesk.com
Thu Feb 15 15:40:03 EST 2007
FDO4: API - Update API documentation included in the FDO header files
Comments:
1) The FDO API documentation is generated from Doxygen comments in
the Managed and Unmanaged API header files. These comments are currently
out of date and need to be updated to reflect the current state of the
FDO API.
2) The FDO Managed APIs are not all being generated by the build
process. This submission enables their generation where appropriate.
Author: Greg Boone
Reviewed By: Don Cameron/Mike Ross
Date: 2007-02-15 14:24:18 -0500 (Thu, 15 Feb 2007)
New Revision: 2521
trunk/Fdo/Unmanaged/Inc/Spatial/SpatialGeometryValidity.h
trunk/Fdo/Unmanaged/Inc/Spatial/SpatialGridTransform.h
Date: 2007-02-15 14:23:49 -0500 (Thu, 15 Feb 2007)
New Revision: 2520
trunk/Fdo/Unmanaged/Inc/Common/Array.h
trunk/Fdo/Unmanaged/Inc/Common/Compare.h
trunk/Fdo/Unmanaged/Inc/Common/Context.h
trunk/Fdo/Unmanaged/Inc/Common/Dictionary.h
trunk/Fdo/Unmanaged/Inc/Common/DictionaryElement.h
trunk/Fdo/Unmanaged/Inc/Common/Dimensionality.h
trunk/Fdo/Unmanaged/Inc/Common/Disposable.h
trunk/Fdo/Unmanaged/Inc/Common/Exception.h
trunk/Fdo/Unmanaged/Inc/Common/FdoTypes.h
trunk/Fdo/Unmanaged/Inc/Common/GeometryType.h
trunk/Fdo/Unmanaged/Inc/Common/IStreamReader.h
trunk/Fdo/Unmanaged/Inc/Common/Io/ByteStreamReader.h
trunk/Fdo/Unmanaged/Inc/Common/Io/FileStream.h
trunk/Fdo/Unmanaged/Inc/Common/Io/MemoryStream.h
trunk/Fdo/Unmanaged/Inc/Common/Io/Stream.h
trunk/Fdo/Unmanaged/Inc/Common/Io/TextReader.h
trunk/Fdo/Unmanaged/Inc/Common/Io/TextWriter.h
trunk/Fdo/Unmanaged/Inc/Common/NamedCollection.h
trunk/Fdo/Unmanaged/Inc/Common/Ptr.h
trunk/Fdo/Unmanaged/Inc/Common/Semaphore.h
trunk/Fdo/Unmanaged/Inc/Common/Stack.h
trunk/Fdo/Unmanaged/Inc/Common/StringP.h
trunk/Fdo/Unmanaged/Inc/Common/Vector.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/Attribute.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/AttributeCollection.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/CharDataHandler.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/CopyHandler.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/Reader.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxContext.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/SaxHandler.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/SkipElementHandler.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/Writer.h
trunk/Fdo/Unmanaged/Inc/Common/Xml/XmlException.h
trunk/Fdo/Unmanaged/Inc/Common/Xsl/Transformer.h
Date: 2007-02-15 14:27:16 -0500 (Thu, 15 Feb 2007)
New Revision: 2522
trunk/Fdo/Unmanaged/Inc/Geometry/DirectPositionImpl.h
trunk/Fdo/Unmanaged/Inc/Geometry/EnvelopeImpl.h
Date: 2007-02-15 14:41:37 -0500 (Thu, 15 Feb 2007)
New Revision: 2523
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/ClientServiceException.h
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/ConnectionManager.h
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/Provider.h
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/ProviderCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/ProviderNameTokens.h
trunk/Fdo/Unmanaged/Inc/Fdo/ClientServices/ProviderRegistry.h
Date: 2007-02-15 14:43:43 -0500 (Thu, 15 Feb 2007)
New Revision: 2524
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/CommandException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/CommandType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/IdentifierCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Locking/ConflictType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Locking/LockStrategy.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Locking/LockType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/LongTransaction/LongTransactionConf
lictResolution.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/LongTransaction/LongTransactionFree
zeOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/LongTransaction/LongTransactionPriv
ilegeOperations.h
ileges.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/LongTransaction/LongTransactionSetO
perations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/OrderingOption.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/ParameterValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/PropertyValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/PropertyValueCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalClassMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalElementMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalElementMappingCollec
tion.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalPropertyMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalSchemaMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Schema/PhysicalSchemaMappingCollect
ion.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/SpatialContext/ISpatialContextReade
r.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/SpatialContext/SpatialContextExtent
Type.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/SpatialContext/SpatialContextMismat
chException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/Sql/ISQLDataReader.h
trunk/Fdo/Unmanaged/Inc/Fdo/Commands/UnitOfMeasure/BaseUnit.h
Date: 2007-02-15 14:45:13 -0500 (Thu, 15 Feb 2007)
New Revision: 2525
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ArgumentDefinition.
h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/FunctionDefinition.
h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ISchemaCapabilities
.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SchemaElementNameTy
pe.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SignatureDefinition
.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionState.h
trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ProviderDatastoreType.h
Date: 2007-02-15 14:56:00 -0500 (Thu, 15 Feb 2007)
New Revision: 2526
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/BLOBValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/BinaryExpression.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/BinaryOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/BooleanValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ByteValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/CLOBValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ComputedIdentifier.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValueCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DateTimeValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DecimalValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DoubleValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ExpressionException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ExpressionType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Function.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/GeometryValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Identifier.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int16Value.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int32Value.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int64Value.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Parameter.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/SingleValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/StringValue.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/UnaryExpression.h
trunk/Fdo/Unmanaged/Inc/Fdo/Expression/UnaryOperations.h
Date: 2007-02-15 14:58:18 -0500 (Thu, 15 Feb 2007)
New Revision: 2527
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/BinaryLogicalOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/BinaryLogicalOperator.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/ComparisonCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/ComparisonOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/ConditionType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/DistanceCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/DistanceOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/Filter.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/FilterException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/GeometricCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/InCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/NullCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/SpatialCondition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/SpatialOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/UnaryLogicalOperations.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/UnaryLogicalOperator.h
trunk/Fdo/Unmanaged/Inc/Fdo/Filter/ValueExpressionCollection.h
Date: 2007-02-15 14:58:44 -0500 (Thu, 15 Feb 2007)
New Revision: 2528
trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModel.h
trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataModelType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataOrganization.h
trunk/Fdo/Unmanaged/Inc/Fdo/Raster/RasterDataType.h
Date: 2007-02-15 15:01:49 -0500 (Thu, 15 Feb 2007)
New Revision: 2529
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AutogenerationException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Class.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinitionCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DeleteRule.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClassCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchemaCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/OrderType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinitionCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaAttributeDictionary.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElementState.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoFeaturePropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoGeometryPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Topology.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraint.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraintCollection.h
Date: 2007-02-15 15:03:41 -0500 (Thu, 15 Feb 2007)
New Revision: 2530
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMappingCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Context.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Deserializable.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMappingCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureContext.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureFlags.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureHandler.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyReader.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyWriter.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureReader.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/NameCollectionHandler.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SchemaMapping.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextFlags.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextReader.h
trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextWriter.h
Date: 2007-02-15 15:09:10 -0500 (Thu, 15 Feb 2007)
New Revision: 2531
trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h
trunk/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h
trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h
Date: 2007-02-15 15:11:22 -0500 (Thu, 15 Feb 2007)
New Revision: 2532
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIArcSegmentAbstract.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICircularArcSegment.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveAbstract.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveAbstractImp.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygon.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstract.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgICurveString.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelope.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometricAggregateAbstract.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometry.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineString.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringSegment.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRing.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiCurvePolygon.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiCurveString.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiGeometry.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiLineString.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiPoint.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIMultiPolygon.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPoint.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygon.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRing.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgIRingAbstract.h
trunk/Fdo/Managed/Src/OSGeo/Geometry/mgISurfaceAbstract.h
Date: 2007-02-15 15:11:40 -0500 (Thu, 15 Feb 2007)
New Revision: 2533
trunk/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGeometryValidity.h
Date: 2007-02-15 15:18:23 -0500 (Thu, 15 Feb 2007)
New Revision: 2534
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStore.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgICreateDataStoreImp
.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStorePropertyD
ictionary.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDataStoreReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIDestroyDataStore.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/DataStore/mgIListDataStores.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIBaseSelect.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDataReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIDelete.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIInsert.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgISelect.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgISelectAggregates.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIUpdate.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgConflictType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIAcquireLock.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIAcquireLockImp.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockInfo.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockOwners.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIGetLockedObjects.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockConflictReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockOwnersReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgILockedObjectReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgIReleaseLock.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgLockStrategy.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Locking/mgLockType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIActivateLong
Transaction.h
TransactionCheckpoint.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIChangeLongTr
ansactionPrivileges.h
ansactionSet.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICommitLongTr
ansaction.h
ansactionImp.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgICreateLongTr
ansaction.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIDeactivateLo
ngTransaction.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIFreezeLongTr
ansaction.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIGetLongTrans
actionCheckpoints.h
actionPrivileges.h
actions.h
actionsInSet.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILTConflictDi
rectiveEnumerator.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgILongTransact
ionCheckpointReader.h
ionPrivilegeReader.h
ionReader.h
ionSetReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgIRollbackLong
Transaction.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransacti
onConflictResolution.h
onFreezeOperations.h
onPrivilegeOperations.h
onPrivileges.h
onSetOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLCommand.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIApplySchema.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchema.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDescribeSchemaMapping
.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIDestroySchema.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalElementMappin
g.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalPropertyMappi
ng.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIActivateSpati
alContext.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatial
Context.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIDestroySpatia
lContext.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgIGetSpatialCon
texts.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContex
tReader.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgSpatialContext
ExtentType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgBaseUnit.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgICreateMeasureU
nit.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIDestroyMeasure
Unit.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIGetMeasureUnit
s.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/UnitOfMeasure/mgIMeasureUnitRea
der.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgCommandType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommand.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgICommandImp.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIFeatureCommand.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Commands/mgOrderingOption.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapab
ilities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCa
pabilities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCa
pabilities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabi
lities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapa
bilities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIRasterCapabi
lities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabi
lities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgITopologyCapa
bilities.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSchemaElement
NameType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgThreadCapabil
ity.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgConnectionState.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnection.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionInfo.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDiction
ary.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgITransaction.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Connections/mgProviderDatastoreType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIExpressionProcessor.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Expression/mgUnaryOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgBinaryLogicalOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgComparisonOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgConditionType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgDistanceOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgIFilterProcessor.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgSpatialOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Filter/mgUnaryLogicalOperations.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRaster.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterPropertyDictionary.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModelType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataOrganization.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgClassType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDeleteRule.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgGeometricType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgObjectType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgOrderType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyDefinition.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgPropertyValueConstraintType.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgSchemaElementState.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgIXmlDeserializable.h
trunk/Fdo/Managed/Src/OSGeo/FDO/Xml/mgIXmlSerializable.h
trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManager.h
trunk/Fdo/Managed/Src/OSGeo/FDO/mgIConnectionManagerImp.h
trunk/Fdo/Managed/Src/OSGeo/FDO/mgIProviderRegistry.h
Date: 2007-02-15 15:31:57 -0500 (Thu, 15 Feb 2007)
New Revision: 2535
trunk/Fdo/Docs/doc_src/Doxyfile_FDOmanaged
trunk/Fdo/Docs/doc_src/Doxyfile_FDOunmanaged
trunk/Fdo/Docs/doc_src/group_and_page_definitions/define_pages.h
Date: 2007-02-15 15:34:00 -0500 (Thu, 15 Feb 2007)
New Revision: 2536
trunk/Providers/ArcSDE/Docs/doc_src/Doxyfile_ArcSDE
trunk/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions/define_pa
ges.h
Date: 2007-02-15 15:35:30 -0500 (Thu, 15 Feb 2007)
New Revision: 2537
trunk/Providers/GDAL/Docs/doc_src/Doxyfile_GDAL
Date: 2007-02-15 15:40:29 -0500 (Thu, 15 Feb 2007)
New Revision: 2538
Added:
trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed
trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/foot
er_managed.html
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/head
er_managed.html
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/foote
r_managed.html
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/heade
r_managed.html
trunk/Providers/GenericRdbms/Docs/doc_src/Makefile.am
trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/MyS
QL/define_pages.h
trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/ODB
C/define_pages.h
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/Make
file.am
trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/Makef
ile.am
Date: 2007-02-15 15:42:50 -0500 (Thu, 15 Feb 2007)
New Revision: 2539
trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages
.h
Date: 2007-02-15 15:44:53 -0500 (Thu, 15 Feb 2007)
New Revision: 2540
Added:
trunk/Providers/SHP/Docs/doc_src/Doxyfile_SHP_managed
trunk/Providers/SHP/Docs/doc_src/headers_and_footers/footer_managed.html
trunk/Providers/SHP/Docs/doc_src/headers_and_footers/header_managed.html
trunk/Providers/SHP/Docs/doc_src/Makefile.am
trunk/Providers/SHP/Docs/doc_src/group_and_page_definitions/define_pages
.h
trunk/Providers/SHP/Docs/doc_src/headers_and_footers/Makefile.am
Date: 2007-02-15 15:46:09 -0500 (Thu, 15 Feb 2007)
New Revision: 2541
trunk/Providers/WFS/Docs/doc_src/group_and_page_definitions/define_pages
.h
Date: 2007-02-15 15:48:02 -0500 (Thu, 15 Feb 2007)
New Revision: 2542
Added:
trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed
trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html
trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html
trunk/Providers/WMS/Docs/doc_src/Makefile.am
trunk/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am
Date: 2007-02-15 16:10:05 -0500 (Thu, 15 Feb 2007)
New Revision: 2543
trunk/Providers/WMS/build.bat
trunk/Providers/WMS/build_linux.sh
Date: 2007-02-15 16:11:16 -0500 (Thu, 15 Feb 2007)
New Revision: 2544
trunk/Providers/SHP/build.bat
trunk/Providers/SHP/build_linux.sh
Date: 2007-02-15 16:12:09 -0500 (Thu, 15 Feb 2007)
New Revision: 2545
trunk/Providers/GenericRdbms/build_linux.sh
Date: 2007-02-15 16:12:35 -0500 (Thu, 15 Feb 2007)
New Revision: 2546
trunk/Providers/GenericRdbms/Src/MySQL/build.bat
trunk/Providers/GenericRdbms/Src/ODBC/build.bat
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070215/83959af9/attachment-0001.html
More information about the fdo-internals
