[fdo-internals] Code Submission Notification - ArcsDE - fixed unit
tests and compiler warnings (ported from svn branches/3.2.x)
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Fri Feb 16 08:14:30 EST 2007
Code Submission Notification - ArcsDE - fixed unit tests and compiler
- Fixed unit test errors on linux. The errors were mainly due to the
overuse of a
transient rotating string buffer. This buffer is transient by nature
and
callers shouldn't hang onto the strings for long.
- fixed linux compiler warning in ArcSDEDescribeSchemaCommand.cpp (used
NULL instead of '\0') .
- Fixed invalid string "LIKE" filters containing "ESCAPE" clauses (that
somehow worked on Windows but not on Linux)
This resolves an issue introduced in prior drops for 870871, where if a
client
connected, then did a select and specified an unqualified class name it
would
fail. This happened because ArcSDEDescribeSchemaCommand::addTable() was
mistakenly assuming a schema name prefix was always being provided.
Revision: 2548
Author: pierredalcourt
Date: 9:08:13 AM, February 16, 2007
Message:
Fixed unit test errors, compiler warnings, etc.
Modified :
/trunk/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp
Modified : /trunk/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
Modified : /trunk/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
Modified : /trunk/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp
Modified : /trunk/Providers/ArcSDE/Src/UnitTest/SelectTests.h
Modified : /trunk/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp
Modified : /trunk/Providers/ArcSDE/TestData/SetupTestData.perl
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070216/0cbbe345/attachment.html
More information about the fdo-internals
