[fdo-internals] dynamic_cast and shared libraries on Linux
Traian Stanev traian.stanev at autodesk.com
Tue Feb 20 13:03:02 EST 2007
Yeah I've seen this problem and I think others have also. We just use
static casts.
Traian
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Tuesday, February 20, 2007 12:43 PM
To: FDO Internals Mail List
Subject: [fdo-internals] dynamic_cast and shared libraries on Linux
Folks,
In the GDAL unit tests I am seeing some dynamic_cast failures that are
quite frustrating.
In particular this error:
  7) test: 17RfpTestBandConfig.testGetNullValue1 (F) line: 32
  RfpTestBandConfig?.h
      "Unhandled FdoException? in testGetNullValue1"
  Seems to be due to this dynamic_cast failing:
          FdoPtr<FdoISelect> cmdSelect = dynamic_cast<FdoISelect*>(cmd);
  cmd is in fact suitable to dynamically cast to FdoISelect, but the
actual
  class is related to FdoISelect somewhat indirectly (through several
layers
  of dirivation and use of a template).  According to the following FAQ
this
  can result in problems with dynamic cast operating across shared
library
  boundaries with gcc 3.x (or later?):
    http://www.gnu.org/software/gcc/faq.html#dso
  Changing the code to a static_cast resolves the issue.  I wonder if we
  need to require a particular version of gcc, or perhaps that we need
  to pursue some of the build options mentioned in the FAQ (which are a
  bit esoteric).  I did quickly try changing the dlopen() in
  FdoConnectionManagerto use the _GLOBAL flag but that did not seem to
  have an effect.
Has anyone else observed this sort of problem?  Are the GDAL unit tests
passing for anyone out there on linux?  If so, what version of gcc
are you using?
For the time being I'm changing the unit tests to use static_cast on
linux,
but this puts application code that uses dynamic_cast in substantial
danger.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
