[fdo-internals] RE: [mapguide-internals] Summer of Code Projects
Greg Boone greg.boone at autodesk.com
Fri Feb 23 14:51:12 EST 2007
Can you also reset the password for user donaldcameron and send him his
new password?
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Friday, February 23, 2007 3:51 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] RE: [mapguide-internals] Summer of Code
Jason Birch wrote:
> If you haven't committed to SVN since the change in servers, then
someone
> will have to set up a new LDAP account for you and grant you the
appropriate
> role for commit access to FDO.  This same account is what you will use
for
> the Trac Wiki updates.
Haris / Jason,
Haris has an account (userid: haris) carried over from the collabnet
configuration.  If needed, I can reset the password manually.
> The current URL for King.Oracle is:
> https://svn.osgeo.org/svn/fdo/trunk/Providers/KingOracle/
> <https://svn.osgeo.org/svn/fdo/trunk/Providers/KingOracle/>
Note that this is where trunk lives.  It is unclear whether Haris
may want to update things in the 3.2.x branch as well which would
live at:
https://svn.osgeo.org/svn/fdooracle/branches/3.2.x/Providers/KingOracle
> Tortoise SVN should work just fine once you get an account set up.
Correct.
> The FDO folks should be able to answer any other questions you might
have.
> Bob, Greg, I'd really appreciate it if this account could be set up as
> quickly as possible and Haris given whatever info he needs to upload
his
> current code.  Mateusz could really benefit from using this as a
template
> for some of the stuff he's doing with the PostGIS provider, and he
gets a
> lot of work done on weekends :)
I can be reached in irc in #mapguide or #osgeo to facilitate account
setup
or answer infrastructure related questions.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
