[fdo-internals] FdoParameterValue and FdoDataValue
Mateusz Loskot
mateusz at loskot.net
Mon Feb 26 20:05:01 EST 2007
I'd like to ask for some suggestion related to usage of
FdoParameterValue and FdoDataValue.
I call SQL command with PostreSQL-specific placeholders:
SELECT * FROM table WHERE id = $1 AND name = $2
I'd like to use the FdoParameterValueCollection to pass input
params that will be bound to placeholders.
I've rev-engineered how to play with this collection and how it works
in commands like FdoISQLCommand, besides one aspect.
The params binding is issued in textual mode, so I convert all params of
all types to their textual representation.
The first obvious soluton is to builda switch statement and manually
convert params from FdoDataValue to a string representation:
// Buffer stringified representation
std::string value;
// pointer got from object of type of FdoParameterVale
FdoPtr<FdoDataValue> data = ...
FdoDataType type = data->GetDataType();
switch (type)
case FdoDataType_Boolean:
FdoBooleanValue* pval = static_cast<FdoBooleanValue*>(data.p);
value = (pval->GetBoolean() ? "TRUE" : "FALSE");
break;
... // and so on for every data type
It will work, but I'm wondering if there is a another possibility,
shorter. As I see, there is FdoDataValue::ToString() member function.
What is the purpose of this ToString() ?
I tested it a bit and it works well with simple types: integral,
real, string.
My question is what can I expect to get from ToString() for types like
FdoDataType_DateType, FdoDataType_BLOB and FdoDataType_CLOB ?
Generally, is it safe to use make the example above simpler by
calling just:
value = data->ToString();
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals
