[fdo-internals] xmin and xmax are reserved keywords
Gavin Cramer gavin.cramer at autodesk.com
Mon Jan 15 14:14:19 EST 2007
I nominate Brent "Mr. Schema Manager" Robinson to so "Go!" (and add the
virtual tags).  :-)
The alternatives to having metaschema are to either:
   1. Reverse-engineer logical schema from physical schema, or...
   2. Use a configuration document (set via
doIConnection::SetConfiguration).
ODBC Provider supports both of these, and does not support ApplySchema.
Gavin
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Monday, January 15, 2007 1:53 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] xmin and xmax are reserved keywords
Gavin Cramer wrote:
> Yes, it looks like you have the right idea there.
Good to know.
So, as I've asked in one of my latest post, who is going to say Go! ?
> Does PostGIS Provider support ApplySchema command?  If so, you'd want
to
> test the full round-trip (ApplySchema followed by DescribeSchema) to
> make sure that there aren't any other places that would be affected.
Yes, I have ApplySchema command provided and I'll run the suggested
test.
By the way, I'm curious what's the alternative to ApplySchema command to
create FDO-enabled datastore?
If a provider doesn't support ApplySchema, how users are supposed to
configure the datastore?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
