[fdo-internals] Using new SVN for PostGIS
Greg Boone
greg.boone at autodesk.com
Tue Jan 16 16:07:29 EST 2007
I am not sure I understand. Please correct me if I am wrong here. Are
you preparing to create your own SVN repository outside fdordbms? If so,
that is not the expected solution. We expect you to merge your changes
into the trunk of fdordbms and have PostGIS be an equal to the ODBC and
MySQL providers with a build process that builds all three. Therefore,
you would have to integrate any changes you made to fdocore or fdodbms
in order to support the PostGIS provider back into the respective
branches of these repositories.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Tuesday, January 16, 2007 2:42 PM
To: fdo-internals
Cc: Jason Birch
Subject: [fdo-internals] Using new SVN for PostGIS
I'm about to start back committing PostGIS FDO to my branch, and I'd
like to ask for recommended strategy regarding fdocore.
Currently, I work on PostGIS FDO using fdocore in r594, from 2006-12-11.
I see there has bene plenty of new changes made to the fdocore/trunk.
Now, should I update my copy of fdocore with current fdocore\trunk or
better with of of branches for 3.2 ?
Which version my PostGIS FDO will be reviewed and merged with,
let's say at the beginning of February ?
Best regards
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
