[fdo-internals] PSC Motion: Repository Merge
Romica Dascalescu
Romica.Dascalescu at autodesk.com
Wed Jan 17 09:19:28 EST 2007
I think we should keep FDOTHIRDPARTY.
Usually Thirdparty is not modifying in the same time with each FDO
version.
In this moment I build only one Thirdparty for trunk and branches/3.2.x
and the first reason is space.
Romi
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, January 16, 2007 6:32 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] PSC Motion: Repository Merge
If we accept this proposal then the requirement to use the following
environment variables would be eliminated since all source code would
reside in a single repository.
FDOUTILITIES
FDOTHIRDPARTY
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
Sent: Tuesday, January 16, 2007 5:53 PM
Subject: [fdo-internals] PSC Motion: Repository Merge
As per the other thread on this topic today, I would like to officially
motion to merge all of the fdoXXX repositories into one. The structure
of the proposed repository is as follows:
/fdo - Repository
/trunk
/fdodev
/core
/tools
/thirdparty
/utilities
/providers
/sdf
/shp
/branches
/3.2.x
/fdodev
Note that tools in this context would be tools written to a particular
release of FDO. If at some point we create one or more tools that work
across multiple versions of the FDO API then we have the option of
creating an /fdotools folder as per Paul Ramsey's recommendation. In
both cases we have the option of including the tools as part of an FDO
release, making them available as a separate release, or making them
available from SVN only.
I would like to proceed on this as quickly as possible, so please vote
within 24 hours.
Thanks,
Bob
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
