[fdo-internals] ArcDE: fix spatial reference SRID issue, misc clean-ups
Pierre Dalcourt pierre.dalcourt at autodesk.com
Tue Jan 23 12:37:26 EST 2007
- Fixed ArcSDE spatial reference SRID issue:
This defect was fixed before, but broke due to recent
performance-enhancement
changes.  This fix only applies to SQL Server SDE databases where
calls to SE_spatialref_get_info_list() fail (for unknown reasons).  In
such a scenario,
this fix changes the way SRID's are retrieved, by looking in the cached
SRID array instead of calling SE_spatialrefinfo_get_srid().
We cannot rely on SE_spatialrefinfo_get_srid() since the SRID is never
set because there is no
SE_spatialrefinfo_SET_srid() method for us to call.
- Misc cleanups:
            - removed ArcSDE's BasicConnectionTests::Command(); now use
FdoCommonMiscutil::FdoCommandTypeToString() instead.
            - added the 3 missing datastore command names to
            - fixed setuptestdata.perl: was missing {} brackets around
if/else statements at line 192, which caused Perl compiler errors.
            - moved a bunch of repeatedly-included headers to stdafx.h :
                        malloc.h
                        string.h
                        math.h
                        sdeerno.h
                        typeinfo
- added some printfs to measure performance of SelectTests::simple() and
BasicSchemaTests::describe()
TESTING PERFORMED:
SelectTests, BasicSchemaTests, SpatialContextTests were ran both with
and
without a hack to force the "alternate code stream" that reads SDE
Spatial
References using pure SQL instead of via the SDE API.
FILES MODIFIED:
******Fdocore******
Modified : Utilities/Common\Src\FdoCommonMiscUtil.cpp
******ArcSDE******
Modified : Providers/ArcSDE/Src\UnitTest\UnitTest.vcproj
Modified : Providers/ArcSDE/Src\UnitTest\SelectTests.cpp
Modified : Providers/ArcSDE/Src\UnitTest\BasicConnectionTests.cpp
Modified : Providers/ArcSDE/Src\UnitTest\BasicSchemaTests.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDERollbackLongTransactionCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDEActivateLongTransactionCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDELongTransactionConflictDirectiveEnum
erator.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEProvider.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESpatialContextReader.h
Modified :
Providers/ArcSDE/Src\Provider\ArcSDEDeactivateLongTransactionCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEDeleteCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEUtils.h
Modified : Providers/ArcSDE/Src\Provider\ArcSDEFilterToSql.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDELockedObjectReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEFeatureReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDETransaction.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESpatialContextReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESpatialContextUtility.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEDataReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEAcquireLockCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEConnection.h
Modified : Providers/ArcSDE/Src\Provider\ArcSDEDestroySchemaCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDELockOwnersReader.cpp
Modified : Providers/ArcSDE/Src\Provider\stdafx.h
Modified : Providers/ArcSDE/Src\Provider\ArcSDESQLDataReader.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDECommitLongTransactionCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESelectCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEUpdateCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEGetLockOwnersCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDEGetLongTransactionsCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDECreateLongTransactionCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDELongTransactionReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESpatialContextUtility.h
Modified : Providers/ArcSDE/Src\Provider\ArcSDELockConflictReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEConnection.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEGetLockInfoCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEApplySchemaCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDESelectAggregatesCommand.cpp
Modified :
Providers/ArcSDE/Src\Provider\ArcSDEGetLockedObjectsCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEReleaseLockCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESchemaManager.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDESQLCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEUtils.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEDescribeSchemaCommand.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEReader.cpp
Modified : Providers/ArcSDE/Src\Provider\ArcSDEInsertCommand.cpp
Modified : Providers/ArcSDE/TestData\SetupTestData.perl
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070123/0b96ed70/attachment.html
More information about the fdo-internals mailing list
