[fdo-internals] Code Submission Notification: ArcSDE +
GenericRDBMS: fix unit test errors
Pierre Dalcourt
pierre.dalcourt at autodesk.com
Fri Jan 26 06:40:55 EST 2007
Author: Pierre Dalcourt
Date: Friday, January 26, 2007
Title: ArcSDE + GenericRDBMS: fix unit test errors
Reviewed by: Jack Lee
Fixed ArcSDE Unit test errors:
Following recent performance changes, the unit tests no longer ran
correctly in
release mode due to applyschema-related metadata no longer being read in
release
mode. Basically, caused the case of class/property names to come back
as upper case
instead of mixed case. this This submission addresses these issues so
that unit tests
can run in release mode again.
Also re-enabled void the unit test ThreadingTests::a_few_threads() since
the sporadic crashing may have been resolved by an arcsde provider fix
from
last November by Gavin Cramer.
Fixed SQL Server Unit test error:
Added a new environment variable "sqlserver_data_root" to point to
the directory where to place test filegroups used for override testing.
If this isn't specified, it defaults to "C:\\Program Files\\Microsoft
SQL Server\\MSSQL\\data".
TESTING PERFORMED:
ArcSDE Unit tests run in release mode with no new errors.
SqlServerFdoApplySchemaTest::TestOverrides() run with no errors.
ArcSDE/Src/UnitTest/ArcSDETests.cpp
ArcSDE/Src/UnitTest/ArcSDETests.h
ArcSDE/Src/UnitTest/BasicInsertTests.cpp
ArcSDE/Src/UnitTest/BasicUpdateTests.cpp
ArcSDE/Src/UnitTest/RecommitTest.cpp
ArcSDE/Src/UnitTest/ThreadingTests.cpp
GenericRDBMS/Src/UnitTest/SqlServer/SqlServerFdoApplySchemaTest.cpp
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070126/b5ceecfc/attachment-0001.html
More information about the fdo-internals
