[fdo-internals] SVN Repository Merge Issues
Greg Boone greg.boone at autodesk.com
Mon Jan 29 13:50:39 EST 2007
I will let everyone know when the merge is complete.
  _____
Sent: Sunday, January 28, 2007 2:41 AM
To: Greg Boone
Cc: FDO Internals Mail List; Shawn Barnes
Subject: Re: [fdo-internals] SVN Repository Merge Issues
We only have three more days of Shawn full time, so I would like to get
this done before he moves on to other things.
Bob
Greg Boone wrote:
Hi Bob,
We are still porting a few defects from 3.2.x -> trunk. I would like to
complete this process before we perform the merge.
Greg.
	-----Original Message-----
	Sent: Sat 1/27/2007 3:01 AM
	To: FDO Internals Mail List
	Cc: Greg Boone; Shawn Barnes
	This does not look too bad, but to save ourselves the hassle
let's just stick with plan A. Until further notice please avoid
submitting anything to trunk.
	Shawn, can you plan to create the new FDO SVN repository on
Monday by merging all of the fdoXXX trunks?
	Thanks,
	Bob
	Greg Boone wrote:
	Hi all,
	At this point, we have identified the following code submissions
that
	were made in the trunk and not in 3.2.x
	            603
	            628
	            652
	Details...
	r603 | brentrobinson | 2006-12-18 10:09:39 -0500 (Mon, 18 Dec
2006) | 1
	line
	Changed paths:
	   M /trunk/Fdo/Unmanaged/Common.vcproj
	   M /trunk/Fdo/Unmanaged/Fdo.vcproj
	   A /trunk/Fdo/Unmanaged/Inc/Common/Compare.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ByteValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DateTimeValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DecimalValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DoubleValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int16Value.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int32Value.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int64Value.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/SingleValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/StringValue.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
	   M
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h
	   M
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h
	   M
/trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h
	   M /trunk/Fdo/Unmanaged/Inc/FdoCommon.h
	   M /trunk/Fdo/Unmanaged/Inc/Makefile.am
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp
	   A
/trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.cpp
	   A
/trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.h
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am
	   M
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp
	   M /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
	   M
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp
	   M
/trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp
	   M /trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc
	FDO342: Support SDF constraint update.
	r628 | brentrobinson | 2007-01-12 17:38:53 -0500 (Fri, 12 Jan
2007) | 1
	line
	Changed paths:
	Removed circular friend reference
	r652 | brentrobinson | 2007-01-23 16:21:24 -0500 (Tue, 23 Jan
2007) | 1
	line
	Changed paths:
	   M /trunk/Fdo/Unmanaged/Inc/Fdo/Raster/DataValueCollection.h
	   M
/trunk/Fdo/Unmanaged/Inc/Fdo/Raster/IRasterPropertyDictionary.h
	   M /trunk/Fdo/Unmanaged/Inc/Fdo.h
	Deprecated redundant Inc/Fdo/Raster/DataValueCollection.h.
	Sent: Friday, January 26, 2007 10:15 AM
	To: 'FDO Internals Mail List'
	Cc: Shawn Barnes
	Subject: RE: [fdo-internals] SVN Repository Merge Issues
	In response to your question, "At this point in time, how
different is
	trunk and 3.2.x", the branch and trunk are mostly identical but
not
	totally identical. Our decision with branching 3.2.x was that
all
	changes submitted into the 3.2.x branch should also be submitted
into
	the trunk. I will have to verify that this is the case. I will
look into
	this and get back to you.
	I know of a couple of submissions that went into the trunk that
did not
	go into the 3.2.x branch. There were several by Brent R. that
come
	immediately to mind (See attached) One significant difference is
that
	Brent dropped a change in the trunk of FDO that changed binary
	compatibility between the branch and trunk.
	Greg
	[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of
Robert Bray
	Sent: Friday, January 26, 2007 1:06 AM
	Cc: Shawn Barnes
	Hmm,
	No responses. So everyone is ok with this, everyone is
dumbfounded and
	shocked into silence, or?
	Any better ideas for how to deal with this merge? We need to
make a
	decision and move forward.
	At this point in time, how different is trunk and 3.2.x?
	Bob
	Robert Bray wrote:
		All,
		Shawn has been tinkering with this and has been able to
successfully
		merge trunk. However it looks like we will not be able
to merge the
		branches. You can see a preview of the merged repository
here:
		http://test.osgeo.net/trac/fdo-merged/browser/.
		Merging in SVN alters the revision numbers, which is why
the branch
		merges do not work. Here is the summary from Shawn:
"I've searched and
		spoken with a few people on subversion merges and
consensus is,
		branches and tags are broken on projects that are being
merged into
		another project, due to the fact that the tag/branch
repository
		specific and don't translate to a new repository
structure."
		So it looks like we may need to have an OLD COLLECTION
OF REPOSITORIES
		(3.2.x) and a NEW REPOSITORY (3.3.x and beyond). This is
not ideal but
		I do not know what else to do at this point.
		Thoughts and ideas welcome?
		Bob
		fdo-internals mailing list
		fdo-internals at lists.osgeo.org
		http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070129/1d29b750/attachment-0001.html
More information about the fdo-internals mailing list
