[fdo-internals] SVN Repository Merge Issues
Greg Boone
greg.boone at autodesk.com
Wed Jan 31 09:46:18 EST 2007
Please let everyone know when the repository is re-opened for commits.
Greg
-----Original Message-----
From: shawn barnes [mailto:sbarnes at dmsolutions.ca]
Sent: Tuesday, January 30, 2007 11:38 AM
To: Greg Boone
Cc: Robert Bray; FDO Internals Mail List
Subject: Re: [fdo-internals] SVN Repository Merge Issues
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
The repositories are up but, commits are locked out until i'm done the
merge.
shawn
Greg Boone wrote:
> Are the 3.2.x branches still open for submissions?
> Sent: Tuesday, January 30, 2007 8:59 AM
> To: Robert Bray
> Cc: Greg Boone; FDO Internals Mail List
> Bob,
> I'm starting the merge now.
> I'm pulling a complete backup of the repositories now (9am EST) and
then
> take the repositories down.
> Merge everything and then put everything backup including the new
merged
> repository.
> Question on naming. What is the name of the new merged repository?
> (repository names can be easily changed)
> shawn
> Robert Bray wrote:
>> Great, thanks Greg! Shawn can you proceed with the merge tomorrow?
>> Thanks,
>> Bob
>> Greg Boone wrote:
>>> The Merges from 3.2.x -> Trunk should now be complete in all FDO SVN
> repositories.
>>> Greg
>>> *From:* Robert Bray [mailto:rbray at robertbray.net]
>>> *Sent:* Sunday, January 28, 2007 2:41 AM
>>> *To:* Greg Boone
>>> *Cc:* FDO Internals Mail List; Shawn Barnes
>>> *Subject:* Re: [fdo-internals] SVN Repository Merge Issues
>>> We only have three more days of Shawn full time, so I would like to
> get this
>>> done before he moves on to other things.
>>> Bob
>>> Greg Boone wrote:
>>> Hi Bob,
>>> We are still porting a few defects from 3.2.x -> trunk. I would like
> to
>>> complete this process before we perform the merge.
>>> Greg.
>>> *Sent:* Sat 1/27/2007 3:01 AM
>>> *To:* FDO Internals Mail List
>>> *Cc:* Greg Boone; Shawn Barnes
>>> This does not look too bad, but to save ourselves the hassle
> let's just
>>> stick with plan A. Until further notice please avoid submitting
> anything
>>> to trunk.
>>> Shawn, can you plan to create the new FDO SVN repository on
> Monday by
>>> merging all of the fdoXXX trunks?
>>> Thanks,
>>> Bob
>>> Greg Boone wrote:
>>> Hi all,
>>> At this point, we have identified the following code submissions
> that
>>> were made in the trunk and not in 3.2.x
>>> 603
>>> 628
>>> 652
>>> Details...
>>> r603 | brentrobinson | 2006-12-18 10:09:39 -0500 (Mon, 18 Dec
> 2006) | 1
>>> line
>>> Changed paths:
>>> M /trunk/Fdo/Unmanaged/Common.vcproj
>>> M /trunk/Fdo/Unmanaged/Fdo.vcproj
>>> A /trunk/Fdo/Unmanaged/Inc/Common/Compare.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/ByteValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DataValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DateTimeValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DecimalValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/DoubleValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int16Value.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int32Value.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/Int64Value.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/SingleValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Expression/StringValue.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
>>> M
> /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraint.h
>>> M
> /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintList.h
>>> M
> /trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintRange.h
>>> M /trunk/Fdo/Unmanaged/Inc/FdoCommon.h
>>> M /trunk/Fdo/Unmanaged/Inc/Makefile.am
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ByteValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DataValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DateTimeValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DecimalValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/DoubleValue.cpp
>>> A
> /trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.cpp
>>> A
/trunk/Fdo/Unmanaged/Src/Fdo/Expression/ExpressionInternal.h
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int16Value.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int32Value.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/Int64Value.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/SingleValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Expression/StringValue.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Makefile.am
>>> M
> /trunk/Fdo/Unmanaged/Src/Fdo/Schema/DataPropertyDefinition.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Fdo/Schema/MergeContext.cpp
>>> M
> /trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp
>>> M
> /trunk/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp
>>> M /trunk/Fdo/Unmanaged/Src/Message/FDOMessage.mc
>>> FDO342: Support SDF constraint update.
>>> r628 | brentrobinson | 2007-01-12 17:38:53 -0500 (Fri, 12 Jan
> 2007) | 1
>>> line
>>> Changed paths:
>>> Removed circular friend reference
>>> r652 | brentrobinson | 2007-01-23 16:21:24 -0500 (Tue, 23 Jan
> 2007) | 1
>>> line
>>> Changed paths:
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo/Raster/DataValueCollection.h
>>> M
> /trunk/Fdo/Unmanaged/Inc/Fdo/Raster/IRasterPropertyDictionary.h
>>> M /trunk/Fdo/Unmanaged/Inc/Fdo.h
>>> Deprecated redundant Inc/Fdo/Raster/DataValueCollection.h.
>>> From: Greg Boone
>>> Sent: Friday, January 26, 2007 10:15 AM
>>> To: 'FDO Internals Mail List'
>>> Cc: Shawn Barnes
>>> Subject: RE: [fdo-internals] SVN Repository Merge Issues
>>> In response to your question, "At this point in time, how
> different is
>>> trunk and 3.2.x", the branch and trunk are mostly identical but
> not
>>> totally identical. Our decision with branching 3.2.x was that
all
>>> changes submitted into the 3.2.x branch should also be submitted
> into
>>> the trunk. I will have to verify that this is the case. I will
> look into
>>> this and get back to you.
>>> I know of a couple of submissions that went into the trunk that
> did not
>>> go into the 3.2.x branch. There were several by Brent R. that
> come
>>> immediately to mind (See attached) One significant difference is
> that
>>> Brent dropped a change in the trunk of FDO that changed binary
>>> compatibility between the branch and trunk.
>>> Greg
>>> From: fdo-internals-bounces at lists.osgeo.org
> <mailto:fdo-internals-bounces at lists.osgeo.org>
>>> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of
> Robert Bray
>>> Sent: Friday, January 26, 2007 1:06 AM
>>> To: FDO Internals Mail List
>>> Cc: Shawn Barnes
>>> Hmm,
>>> No responses. So everyone is ok with this, everyone is
> dumbfounded and
>>> shocked into silence, or?
>>> Any better ideas for how to deal with this merge? We need to
make
> a
>>> decision and move forward.
>>> At this point in time, how different is trunk and 3.2.x?
>>> Bob
>>> Robert Bray wrote:
>>>> All,
>>>> Shawn has been tinkering with this and has been able to
> successfully
>>>> merge trunk. However it looks like we will not be able to merge
> the
>>>> branches. You can see a preview of the merged repository here:
>>>> http://test.osgeo.net/trac/fdo-merged/browser/.
>>>> Merging in SVN alters the revision numbers, which is why the
> branch
>>>> merges do not work. Here is the summary from Shawn: "I've
> searched and
>>>> spoken with a few people on subversion merges and consensus is,
>>>> branches and tags are broken on projects that are being merged
> into
>>>> another project, due to the fact that the tag/branch repository
>>>> specific and don't translate to a new repository structure."
>>>> So it looks like we may need to have an OLD COLLECTION OF
> REPOSITORIES
>>>> (3.2.x) and a NEW REPOSITORY (3.3.x and beyond). This is not
> ideal but
>>>> I do not know what else to do at this point.
>>>> Thoughts and ideas welcome?
>>>> Bob
>>>> _______________________________________________
>>>> fdo-internals mailing list
>>>> fdo-internals at lists.osgeo.org
> <mailto:fdo-internals at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/fdo-internals
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.1 (GNU/Linux)
iD8DBQFFv3RbhzE9g90MFjcRAha5AJ43VgdgAdo0RBptrl/g9EPQB9ytpACeOHCo
dvq+LGHNCW5nwFKCOi6SwjY=
=UEUH
-----END PGP SIGNATURE-----
More information about the fdo-internals
