[fdo-internals] Code Submission Notification: ODBC: 863839.01
Connect to Access on Vista
Gavin Cramer
gavin.cramer at autodesk.com
Wed Jan 31 18:00:08 EST 2007
The following changes has been committed to the 3.2.x branch ...
Summary:
ODBC: 863839.01 Connect to Access on Vista
Description:
This works around a regression in the Microsoft ODBC driver for Access,
on
Microsoft Vista (Business Edition).
The function to get information about ODBC schema names fails on Vista.
Access
doesn't support schemas anyway, so the ODBC Provider code was changed to
proceed
with the no-schema logic if the ODBC API function call fails.
Also, a SqlCmdTest unit test that incorrectly cast a DateTime value was
fixed.
Modified: D:\fdo8\Providers\GenericRdbms\Src\ODBCDriver\users_.c
D:\fdo8\Providers\GenericRdbms\Src\UnitTest\Common\FdoSqlCmdTest.cpp
Gavin Cramer
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070131/21ddb4da/attachment.html
More information about the fdo-internals
