[fdo-internals] FDO RFC 7 - Add New
	MethodstoFdoClassDefinition-Take II
    Barbara Zoladek
    barbara.zoladek at autodesk.com
    Mon Jul 30 21:59:23 EDT 2007
> I am trying to understand how FDO client application can use
information
> that FDO Class is based on RDBMS View ?
Since the view updateability cannot be determined reliably, the
application knowing that the class is based on the virtual object would
be able to prevent data editing. The alternative would be to let the
user insert/update data and hit the error at the target datastore and
tell user that the operation is invalid. That's not the right approach.
Another example could be the case when application is caching data and
must keep caches is sync.
> For RDBMS application View can be same as Table. Data can be
modifided,
> index created, triggers created, etc..
> For application's there is no difference if data is coming from View
or
> Table.
Well, not exactly. Only simple views are updateable. Views based on
complex queries require instead-of-triggers to make them updateable. You
cannot determine if the view is updateable or not. True that for
example, SQL Server allows creating an index (Oracle does not), but
still it depends on the underlying database object.
Thanks,
Barbara.
> -----Original Message-----
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> Sent: Monday, July 30, 2007 5:05 PM
> To: FDO Internals Mail List
> Subject: RE: [fdo-internals] FDO RFC 7 - Add New
information
modifided,
or
> Table.
> Haris
> [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Barbara
> Zoladek
> Sent: Monday, July 30, 2007 10:50 PM
> Subject: RE: [fdo-internals] FDO RFC 7 - Add New Methods
> Hi Haris,
> Yes, that's the case.
> Thanks,
> Barbara.
> > Sent: Monday, July 30, 2007 4:43 PM
> > Subject: RE: [fdo-internals] FDO RFC 7 - Add New Methods to
> > II
> > Hi Barbara,
> > I don't understand in which cases provider should set that FDO Class
> is
> > Virtual.
> > In the case when FDO Class is based on RDBMS View ?
> > Haris
> > Zoladek
> > Sent: Monday, July 30, 2007 9:35 PM
> > Subject: [fdo-internals] FDO RFC 7 - Add New Methods to
> > FdoClassDefinition -Take II
> > Hi,
> > Thanks for all your comments on RFC-7.
> > The new version is now available:
> >  http://trac.osgeo.org/fdo/wiki/FDORfc7
> > Thanks,
> > Barbara.
> > fdo-internals mailing list
> > fdo-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
