[fdo-internals] [Select] Empty reader or NULL?
Greg Boone greg.boone at autodesk.com
Mon Mar 19 22:07:36 EDT 2007
In this specific case, I would image that an exception would be thrown
stating that 'class non-existing-feature-class-name does not exist'.
In other cases, where no valid data is available for return, but an
exception is not warranted, I would recommend not returning NULL. I
recommend returning an instantiated Reader. When the user calls
ReadNext(), it will return false.
Greg
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Monday, March 19, 2007 8:43 PM
To: fdo-internals
Subject: [fdo-internals] [Select] Empty reader or NULL?
I'd like to ask about semantic details of FdoISelect::Execute()
operation, especially in DBMS provider.
For instance, if a feature class is directly mapped to table in a
database.
Let's imagine the code below is called by a client:
// Connection is Open
FdoPtr<FdoIConnection> conn;
FdoPtr<FdoISelect> cmd;
cmd = static_cast<FdoISelect*>(
    conn->CreateCommand(FdoCommandType_Select));
assert(0 != cmd);
// NOTE: Querying non-existing class
cmd->SetFeatureClassName(L"non-existing-feature-class-name");
// XXX - What Execute() is supposed to return here?
FdoPtr<FdoIFeatureReader> reader = cmd->Execute();
My question is as in line marked with XXX:
If a client queries for a feature class that does not
exist (a non-existing table), what the Execute() operation is supposed
to return?
Is it safe to return NULL pointer to a reader?
Or it should return a kind of empty (terminating) reader, however here I
have no idea how to achieve this kind of feature.
Or an exception is thrown from Execute()?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
