[fdo-internals] Re: FDO raster image data model does not provide the actual number of bits used by certain image data formats (Re: FdoRfc1 & FdoRfc2)
Fri Mar 23 13:00:10 EDT 2007
Sarat Venugopal wrote:
>> OK, please go ahead and make a case for doing both.  Off hand, seems
>> like duplication and unnecessary complexity.
> Formats such as Ikonos distinguish themselves by the actual number of
> bits used, so I think including this field in the data model helps API
> clients with various things without performing additional processing.
> Besides, this information could be used to arrive at the approximate
> minimum and maximum values which is superior to a method that only
> involves sampling the image.
Sarat,
But I don't see how this provides something that wouldn't be provided
by the min/max handling since for an Ikonos image you can just return
0/2047 for the min/max.
> I certainly don't see any complexity in adding this additional field.
There is extra complexity in every single property, or method added to
an interface.  It wouldn't take much value to justify this very small
increment of complexity, but it is extra complexity.
The multiple approaches to scaling will certainly complicate future
provider and application code.  If I write application code I will be
faced with deciding which information to use, and have to start second
guessing which providers implement which well.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the fdo-internals mailing list
