[fdo-internals] FDO 3.3 compatible MrSID and ECW Plugins
Jason Birch Jason.Birch at nanaimo.ca
Sun Nov 25 20:42:17 EST 2007
For the ECW provider and what I believe is the distributed MapGuide GDAL DLL, I'm getting "The procedure entry point ??1CPLMutexHolder@@QAE!XZ could not be located in the dynamic link library gdal14.dll"
The MrSID plugin appears to work.
With your SDK dll, everything works fine.  Except that I'm still seeing the faint white line on the image boundaries with the ECW plugin (and not on the SID one?) Different images though.
Jason
Subject: Re: [fdo-internals] FDO 3.3 compatible MrSID and ECW Plugins
I have prepared new plugins based on the GDAL 1.4.4 RC1 source.
I'd appreciate folks trying the above plugins.  The whole VC8 build SDK is
available at:
   http://home.gdal.org/dl/gdal14_vc8/gdal144_vc8_sdk.zip
though this should not in theory be needed.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-internals/attachments/20071125/7c286934/attachment.bin
More information about the fdo-internals mailing list
