[fdo-internals] RE: [mapguide-internals] Case
sensitivitychangeinMGOS 1.2?
Robert Fortin
robert.fortin at autodesk.com
Tue Oct 9 15:56:46 EDT 2007
Jason,
That change was done around March (in build 54), to make the "like"
operation consistent with the rest of the other operations.
It means "Like" is now case sensitive.
And yes, with this, it included support for lower and upper function so
that your call can be replaced with something like this
Upper(lastname) like 'SMITH%'
RF
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, October 09, 2007 3:29 PM
To: FDO Internals Mail List; MapGuide Internals Mail List
Subject: RE: [fdo-internals] RE: [mapguide-internals] Case
OK, thanks.
It would be useful if there was some way of overriding this. I want my
users to be able to find things without having special knowledge of the
data. If there is a lower() or upper() function in SDF, I guess I could
use that to force comparison of like-case?
Jason
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Tuesday, October 09, 2007 11:56
Subject: RE: [fdo-internals] RE: [mapguide-internals] Case sensitivity
changeinMGOS 1.2?
I think at some point the behavior of LIKE was changed from case
insensitive (like old MapGuide) to case sensitive. I'm fuzzy on the
details of when that happened.
Traian
> From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-
> Sent: Tuesday, October 09, 2007 2:54 PM
> To: MapGuide Internals Mail List; FDO Internals Mail List
> Subject: [fdo-internals] RE: [mapguide-internals] Case sensitivity
> change inMGOS 1.2?
> I suppose that I should be explicit: the case sensitivity is around
> attribute values in filters. Such as lastname like 'Smith' not
> returning rows where lastname == 'SMITH'.
> Jason
> From: Jason Birch
> Subject: [mapguide-internals] Case sensitivity change in MGOS 1.2?
> Anyone know if something has changed in MapGuide 1.2 or FDO 3.2.3 that
> would cause my SDF queries to be case sensitive, where they weren't in
> 1.1? Does this have anything to do with the locale changes?
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
