[fdo-internals] OGR ProjConverter.h/.cpp
Greg Boone
greg.boone at autodesk.com
Fri Oct 19 16:08:42 EDT 2007
Ok. What I will do to try and make things easier is create a secondary
Release configuration that expects all the bells and whistles and have
the default Release configuration link against the minimum set.
NOTE: The updated provider configuration will reference GDAL from its
relative location in Thirdparty
I would like to get a set of notes together that describes how to build
a fully fledged OGR provider will a full set of GDAL/OGR capabilities
and post these on the wiki. Can someone volunteer this information? I
will validate the steps and be responsible for the wiki content.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, October 19, 2007 4:02 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] OGR ProjConverter.h/.cpp
Yes, that's the thing with OGR. One can compile it with a zillion
external libraries, which then imply that the provider has to link with
these also. I suggest you do a minimal configuration first, so link to a
basic OGR build, without OCI, PQ, etc... Then we can go from there.
I keep a special directory on my computer, where I have set up a full
tree of all of these components and basically that's the only place
where I can do a fully loaded OGR provider build. I would expect if
someone needs to support weirdo formats, they will have to do their own
provider build, that links against the correct OGR.
Traian
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Friday, October 19, 2007 3:56 PM
Ok, the questions keep coming...
The release build expects to find
proj.lib
geos.lib
geos_c.obj
libpq.lib
oci.lib
So, if we want to incorporate the OGR provider into the top level Open
Source build process, do we expect that proj, geos, postgresql and
oracle client be installed and a version of GDAL be available that uses
them ?
Greg
Stanev
Sent: Friday, October 19, 2007 3:43 PM
I do not do debug builds, so only the Release build is up to date. The
settings for Debug are wrong. This is mostly because with GDAL one can
only have a single build when using its regular build tools. If you try
to do a debug provider build that links to release OGR libraries, there
are lots of problems (link and/or runtime), so I did not pursue that
path.
Traian
Sent: Friday, October 19, 2007 3:39 PM
For the OGR provider, the linker settings are different between the
Debug and Release configurations:
Additional dependencies
Release:
fdo.lib fdocommon.lib fdogeometry.lib ogr.lib cpl.lib ogrsf_frmts.lib
ogrsf_frmts_sup.lib proj.lib geos.lib libpq.lib wsock32.lib oci.lib
geos_c.obj xerces-c_2.lib
Debug:
ogrsf_frmts_sup.lib
Delay-Load DLLs
Release:
oci.dll;fdo.dll;fdogeometry.dll
Debug
Can I get a clarification on the expected settings?
Greg
Stanev
Sent: Friday, October 19, 2007 3:14 PM
I think that one is supposed to be optional, for specifying any
overridden coordinate systems. I don't have this file on my drive.
Sent: Friday, October 19, 2007 3:12 PM
Is there also supposed to be a file: projections.txt?
Stanev
Sent: Friday, October 19, 2007 2:51 PM
That's mostly because I'm an idiot who can't use SVN. They should be
there now.
Traian
Sent: Friday, October 19, 2007 2:49 PM
Subject: [fdo-internals] OGR ProjConverter.h/.cpp
Hi All,
I am trying to build the OGR provider. The Windows solution requires
ProjConverter.h and ProjConverter.cpp. What are the source of these
files? They do not seem to be in the SVN.
Greg
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20071019/a49d313e/attachment.html
More information about the fdo-internals
