FW: [fdo-internals] S013-GB3: Build: Add PostGIS to build process (LINUX)
Greg Boone greg.boone at autodesk.com
Thu Oct 25 11:24:47 EDT 2007
Hi All,
Can I get some guidance on how to configure the GDAL build so that OGR
support is fully enabled?
Here are the settings I used.
./configure --with-gif=internal --with-jpeg=internal --with-png=internal
--with-libtiff=internal --with-geotiff=internal --with-pg=no
--with-python=no --with-libz=internal
However, I still am getting the following missing symbols in the OGR
.so:
undefined symbol: _ZN13OGRDataSource17DestroyDataSourceEPS_
(./libOGRProvider.so)
undefined symbol: _ZN20OGRSFDriverRegistrar4OpenEPKciPP11OGRSFDriver
undefined symbol: OGRRegisterAll        (./libOGRProvider.so)
Sent: Thursday, October 25, 2007 9:45 AM
To: Greg Boone
Subject: RE: [fdo-internals] S013-GB3: Build: Add PostGIS to
buildprocess(LINUX)
Hi Greg,
Did you tried the following
ldd -r libOGRProvider.so
I getting the following missing symbols:
Sent: Thursday, October 25, 2007 9:29 AM
To: Jack Lee
buildprocess(LINUX)
Yes. I forgot that one. I will drop it.
Sent: Thursday, October 25, 2007 9:01 AM
To: Greg Boone
Subject: FW: [fdo-internals] S013-GB3: Build: Add PostGIS to
buildprocess(LINUX)
Hi Greg,
Building OGR seems to be ok.
I having problems building PostGIS:
configure.in:66: required file `Doc/Makefile.in' not found
Do you forget to drop Makefile.am for the Doc directory?
Sent: Wednesday, October 24, 2007 4:22 PM
To: Greg Boone
buildprocess(LINUX)
Hi Greg,
I will be doing a full build tonight. I will post to the mailing list if
I still have a problem.
Sent: Wednesday, October 24, 2007 4:18 PM
To: Jack Lee
buildprocess(LINUX)
Can you post to 'fdo-internals' and have others test?
Sent: Wednesday, October 24, 2007 3:42 PM
To: Greg Boone
buildprocess(LINUX)
Importance: High
Hi Greg,
I am having problems building ogr.
./build_linux.sh  --w ogr
Eventually, I get the following:
g++ -DPACKAGE_NAME=\"FDOOGR\" -DPACKAGE_TARNAME=\"fdoogr\"
-DPACKAGE_VERSION=\"3.3.0\" "-DPACKAGE_STRING=\"FDOOGR 3.3.0\""
-DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdoogr\"
-DVERSION=\"3.3.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
-DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
-DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
-DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -I. -I.
-I../../Fdo/Unmanaged/Inc -I/build1/slate/Thirdparty/gdal/ogr
-I/build1/slate/Thirdparty/gdal/ogr/ogrsf_frmts
-I/build1/slate/Thirdparty/gdal/port -I../../Thirdparty/gdal/ogr
-I../../Thirdparty/gdal/ogr/ogrsf_frmts -I../../Thirdparty/gdal/port
-MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -MT OgrFdoUtil.lo -MD -MP -MF
.deps/OgrFdoUtil.Tpo -c OgrFdoUtil.cpp  -fPIC -DPIC -o
.libs/OgrFdoUtil.o
In file included from /build1/slate/Thirdparty/gdal/ogr/ogr_core.h:126,
                 from
/build1/slate/Thirdparty/gdal/ogr/ogr_geometry.h:233,
                 from
/build1/slate/Thirdparty/gdal/ogr/ogr_feature.h:147,
                 from
/build1/slate/Thirdparty/gdal/ogr/ogrsf_frmts/ogrsf_frmts.h:97,
                 from stdafx.h:56,
                 from OgrFdoUtil.cpp:19:
/build1/slate/Thirdparty/gdal/port/cpl_port.h:189:22: direct.h: No such
file or directory
make: *** [OgrFdoUtil.lo] Error 1
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Wednesday, October 24, 2007 3:35 PM
To: FDO Internals Mail List
buildprocess(LINUX)
Importance: High
I just want to clarify that the neither the PostGIS nor the OGR Linux
binaries have been tested/validated. This will have to be done before
they can be released as part of the FDO 3.3.0 beta.
I will need other members of the community to assist with this task.
Greg
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, October 24, 2007 12:47 PM
buildprocess(LINUX)
Awesome...
  _____
Subject: [fdo-internals] S013-GB3: Build: Add PostGIS to build
process(LINUX)
Title:            Build: Add PostGIS to build process (Linux)
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20071025/3444c203/attachment-0001.html
More information about the fdo-internals mailing list
