[fdo-internals] Linux PostGIS provider build failure
larry white larz at neomatix.ca
Thu Oct 25 16:36:48 EDT 2007
Here is some info on an initial attempt to build the linux PostGIS
provider.
Build environment
Fedora Core 6
gcc 4.1.1
(same environment I've used for previous builds of FDO and MapGuide OS)
fdocore compiled without any problems and FDO unit tests ran successfully.
However, there was an error during the PostGIS provider build.
Here's the error:
Connection.h:273: error: extra qualification
'fdo::postgis::Connection::' on member 'GetPgCurrentSchema'
make[2]: *** [ApplySchemaCommand.lo] Error 1
make[2]: Leaving directory
`/home/mgDev/fdo-3-3.0/trunk/Providers/PostGIS/Src/Provider'
-- larry
More information about the fdo-internals mailing list
