[fdo-internals] Linux PostGIS provider build failure
Mateusz Loskot mateusz at loskot.net
Thu Oct 25 18:05:40 EDT 2007
Larry,
Thanks for reporting this issue.
I've fixed it and commited to the SVN.
-- Mat
larry white wrote:
> Here is some info on an initial attempt to build the linux PostGIS
> provider.
> Build environment
> Fedora Core 6
> gcc 4.1.1
> (same environment I've used for previous builds of FDO and MapGuide OS)
> fdocore compiled without any problems and FDO unit tests ran successfully.
> However, there was an error during the PostGIS provider build.
> Here's the error:
> Connection.h:273: error: extra qualification
> 'fdo::postgis::Connection::' on member 'GetPgCurrentSchema'
> make[2]: *** [ApplySchemaCommand.lo] Error 1
> make[2]: Leaving directory
> `/home/mgDev/fdo-3-3.0/trunk/Providers/PostGIS/Src/Provider'
> -- larry
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
