[fdo-internals] Remove Generated Files
Greg Boone
greg.boone at autodesk.com
Tue Oct 30 09:41:14 EDT 2007
Agreed.
-----Original Message-----
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Mateusz
Loskot
Sent: Tuesday, October 30, 2007 6:41 AM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Remove Generated Files
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> Greg Boone wrote:
>>> IMHO... I would seriously consider removing all generated files
>>> and require the user call build_linux.sh, which is what the
>>> documentation suggests now.
>> I'm all for that. IMO this is a very good practice, especially if a
>> project does follow GNU configuration based on ./configure script,
>> Makefile.am files and autotools chain.
>> In comparison, this is not true for GDAL, so it would be not easy
>> to remove ./configure and brothers from the repo.
> Greg,
> I, on the other hand, think this is a bad idea. If the environment
> is at all sensitive to the version of automake and autoconf, forcing
> developers working from SVN to rebuild all the derived files runs the
> significant risk of problems related to them having the wrong
> versions of automake and autoconf.
> I've been driven away from involvement in a number of projects by
> this sort of a annoyances, and I think we would be making it harder
> for people to be involved in FDO causually.
Yes, I agree with Frank that there is such risk.
What I don't understand is that current building configuration
regenerates ./configure & friends always by default, so current solution
does not avoid this kind of problems pointed by Frank.
Second, even if we provide ./configure, users still *have* to generate
Makefile.in and Makefile files, so appropriate tools & its versions are
required sill.
What I want to say here is that not removing configure does not solve
potential problems with autotools versions.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals
