[fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
Badreddine Karoui badreddine.karoui at autodesk.com
Tue Apr 1 12:19:55 EDT 2008
Only the existing binary encoder/decoder is maintained for backward compatibity. A new binary encoder/decoder will be created to write SQLite compliant data. I wouldn't call that 2 providers in one DLL.
The SDF provider is at best 3 years old and can hardly be called "legacy". I'm sure any performance used in the new code can apply to the SDF provider, wouldn't?
Badreddine
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, April 01, 2008 12:09 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
It would be like having two providers in one DLL. There would be two code paths for everything, and I don't think all that much code would be shared between the two, apart from query execution.
The SQLite provider (which I have already written), is right now significantly faster than SDF in use cases that MapGuide cares about, even with the virtual machine in the way. For BBOX spatial query on several data sets I tried, it is at least 10 times faster than SDF. I think that if the SDF codebase is used as a starting point, this would not have been the case, due to all the legacy code that is in SDF.
Traian
> bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
> Sent: Tuesday, April 01, 2008 11:56 AM
> Regardless of the terminology; these two providers persist their data
> to an SQLite file. The idea would be to upgrade the SDF provider to
> write SQLite complaint data blocks that can be consumed by other SQLite
> tools/applications. At the same time the SDF provider maintains its
> backward compatibility to its current format. We get a seemless
> transition to the new format and stability since the bulk of the SDF
> provider code will be re-used. Also, since the SDF will continue to
> bypass the SQLite virtual machine, the performance will not be degraded
> at least not by much.
> Badreddine
> Sent: Tuesday, April 01, 2008 11:44 AM
> The RFC does not propose "enhancements". It proposes a new format.
> Traian
> > bounces at lists.osgeo.org] On Behalf Of Greg Boone
> > Sent: Tuesday, April 01, 2008 11:32 AM
> SQLite
> > Maybe this question comes a bit too late, but why can't the
> > enhancements proposed in the RFC be made in the existing SDF provider
> > as opposed to building a whole new provider?
> > Greg
> > bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> > Sent: Monday, March 31, 2008 5:29 PM
> SQLite
> > +1
> > Haris
> > [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> > Sent: Monday, March 31, 2008 7:51 PM
> > Subject: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
> > Given the modifications to the RFC to address questions raised on
> this
> > list, and a lack of further discussion I hereby move to approve FDO
> RFC
> > 16 - FDO Provider for SQLite.
> > https://trac.osgeo.org/fdo/wiki/FDORfc16
> > +1 from me
> > Jason
> > From: Traian Stanev
> > Subject: RE: [fdo-internals] FDO RFC 16 - FDO Provider for SQLite
> > I think it has enough stuff in it to vote on.
> > fdo-internals mailing list
> > fdo-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/fdo-internals
> > No virus found in this incoming message.
> > Checked by AVG.
> > Version: 7.5.519 / Virus Database: 269.22.1/1350 - Release Date:
> > 3/30/2008 12:32 PM
More information about the fdo-internals mailing list
