[fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
Badreddine Karoui badreddine.karoui at autodesk.com
Tue Apr 1 12:29:10 EDT 2008
Actually, it's been an outstanding request to make SDF play nice with SQLite and it's the logical next step for the SDF provider. Mostly for non-technical reason, we never got around to work on that next step. If we do and should do, then these 2 providers become very similar if not the same.
Badreddine
-----Original Message-----
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
Sent: Tuesday, April 01, 2008 12:22 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Vote: FDO RFC 16 - FDO Provider for SQLite
Badreddine Karoui wrote:
> Regardless of the terminology; these two providers persist their data to an
> SQLite file. The idea would be to upgrade the SDF provider to write SQLite
> complaint data blocks that can be consumed by other SQLite
> tools/applications. At the same time the SDF provider maintains its backward
> compatibility to its current format. We get a seemless transition to the new
> format and stability since the bulk of the SDF provider code will be
> re-used. Also, since the SDF will continue to bypass the SQLite virtual
> machine, the performance will not be degraded at least not by much.
Folks,
I'll concede I have limited familiarity with SDF, but I think the
differences are so vast that the fact that aspects of sqlite unpin both
is not very relavent.  It's a bit like saying that since GeoRSS and
GML are both XML based formats they should be handled through the same
driver.
I think distinct drivers for these very different situations is appropriate.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
